LCR-T4 electronics components tester ATMega328 - Test and Review
TechEkspert 219066 650
  • #301 16712991
  • #302 16713019
    DiZMar
    Adamcyn wrote:
    ... You are very critical of this tester - you probably have not received it from Gulsona screwdriver for protection. :) ...
    I got a screwdriver, of course. This does not change my honest assessment. It is difficult to name regularity irregularity . Out of range this out of range not any random indication . A simple weight outside the range squeals or otherwise indicates that the range has been exceeded and not after the subsequent positions of the same mass each time different. A simple voltmeter, even a tilting device, bases a hint on the final limiter or even destroys it if the range is too high. A heavy truck with a heavy banner simply throws it. Give more examples?
  • #303 16713092
  • #304 16713432
    pawelr98
    I ordered this tester from gadgets. It will be useful because I have to sort dozens of TO-92 transistors with a spout. I only have a question about the power supply. How much can you give? 9V batteries do not use because the instruments are converted to external power supply. LCR-T4 electronics components tester ATMega328 - Test and Review Two ZX5.6 (5.6V 12.5W) generators and a regular rectifier.
  • #305 16713508
  • #306 16713510
    DiZMar
    Add 2 rectifier diodes (direction of conduction) to the receiver in series and you will receive approx. 7V and it will be enough. The power supply is over a dozen V. I use an old 6V / 1.3Ah gel battery and I think that once a year the top-up is enough.
  • #307 16713580
  • #308 16713799
    bestler
    And the 9V battery lasts for a year and I do not know why you're combining.
  • #309 16713851
    sylweksylwina
    Because, you can :) I know that this is over form over the content, but I gave my inverter the converter, charging module and battery from the phone. When I'm done, I can give pictures.
  • #310 16714480
    Jawi_P
    Level 36  
    It's a remake, combinations have any sense at all? I understand that to make them out of boredom, and only for that reason :) Neither aesthetic nor economic or ergonomic. One of my multimeter is 4xAA, it draws like crazy, it has a power socket. I use the power supply because it is originally. The second meter on 6F22 (9V), I exchange the battery on average, I think once every 2 years. What is the point of babasing? This tester from Elektroda, will also be powered by the original battery because I do not see the point at the moment to convert it into something else.
  • #311 16714543
    pawelr98
    In universal meters, they often used up much faster. Battery voltage drops have deteriorated the precision of measuring diodes and small resistor resistors. I happen to do long measurements. Recently, for example, for about an hour I measured the base current of the transistor which worked at 90 ° C (KD502 at almost 60W power). To the extent that the sticks can be bought almost anywhere, the 9V batteries are different. To buy such a battery, sometimes I had to go to another store. And just like that I just plug in this power supply and I have peace. The meter from the picture has a 7.5V zener in it which lowers the voltage to the required level. As I mentioned earlier, the tester will be doing a long series of measurements. I have a lot of items to check out. Depending on what I disassemble, I can even reach several transistors after a few minutes. I have a lot of electronic scrap which serves me as a source of components. I have a small bucket full of coils, transformers or chokes.
  • #312 16714633
    E8600
    I see that not only I do not like 6F22 (9V). These batteries are fortunately less and less popular in home appliances. The price of these batteries does not translate into capacity and the voltage drops quickly to approx. 6V.
  • #313 16714704
    bestler
    Me in the meters that are often included 10h / day the battery lasts for quite a long time, a few months I think up to half a year. In the away meter used, say, an hour once every three days, I do not remember when I changed the battery, but very long ago. I use the same MY68 meters. In the discussed tester, I have been using batteries for a year, I use it every few days and the battery shows 8.99, and for some time there has been a similar value for some time. But ... I have a clamp meter from Sonel, which I use once in a few weeks (measurements rather short, up to several minutes max) and the battery often sits up that personally annoys me - but I can not do anything about it except to bring a stock with me. I also had a gauge some cheap, I do not remember the brand and the battery also fell down every now and then, I've got rid of it. In my opinion, a lot depends on a specific meter, some use batteries faster slower. Just like with computer mice, I used to have such a powered R6 and had to exchange it once a week. Then my next mouse was better for him, the battery lasts half a year or more.
  • #314 16714823
    Jawi_P
    Level 36  
    Well, I do not like it too, but I would not like to change the power system when I think that the battery can last months or years. Sure, if I had to change the batteries at least once every 4-6 months, maybe I would think about it, but sooner than the battery, which is in the price of a good battery. Although I have recently listened to my colleagues in the forum and bought these batteries in Carefur, alkaline for 5pln with the hook. Anyway, in stores I look, electronic online are and after 4, x pln, also alkaline. So when shopping you can think about adding to the order. Let it lie. The change in power is the idea how it will become really difficult to access.
  • #315 16714843
    gumisie
    " Electronic components tester "A great gadget, so I can test it and share specific comments, not to go into what power supply or battery I use to power this tester. It's a pity that you can not measure the inductance below 10?H with this tester, but let me add that the tester I received in case measuring the inductance, the difference is only 2% from the actual (I have an inductance meter) is probably a plus for this tester.
  • #316 16715174
    pawelr98
    You can buy interesting rechargeable batteries from Chinese. In a typical 6F22 casing, we have a lipo accumulator, a 9V converter and a charging system. Charging via microUSB. They also make such batteries in the AA and AAA variant. I would buy it myself, but 9V costs 25-30 PLN / piece. The capacity is also so-so because 400mAH (moreover, somewhat overstated by those who started and tested the link). One of the things I want to see is how it will react on TL431 with the REF pin shorted to the cathode. In this configuration it behaves like a 2.5V zener diode.
  • #317 16715188
    gumisie
    Dear friend, as long as you are the lucky owner of this tester, it's simpler than to connect this TL_a.
  • #318 16715610
  • #319 16721627
    vodiczka
    I was interested in what the tester will show in the case of three identical resistors connected in a star and connected to the three pins of the tester. Resistors 680? 5%, resistance measured with a 665-672? multimeter. The right picture shows the result after inverting the tips by 180 ° LCR-T4 electronics components tester ATMega328 - Test and Review
  • #320 16721785
    E8600
    Tester ordered I hope that it will come all in a set with a screwdriver and that I can turn ithehe. I will say that I was skeptical but you have convinced me in part. It will be useful mainly for coils and transistors. After testing, you can see that sometimes it can get lost but it is not a total layman's equipment. The only thing I would add is a switch on the power cord so that you do not draw unnecessarily energy (I know that little but always the battery will last longer) as it lies in the drawer and how it will go into detailed testing mode to speed up the next measurement by disconnecting power.
  • #321 16721807
  • #322 16721831
    E8600
    Adamcyn wrote:
    And what about the calibration? This is a one-off operation, do you have to repeat it after replacing the battery?
    If you do not change the battery, you do not need to calibrate? I have spied this solution here.
  • #323 16721854
    vodiczka
    Either that's another solution or this presenter has done something. For me (the first three from left), both the upper and lower contacts are 1-2-3.
    I did not calibrate the tester. :cry: What is the calibration?
  • #324 16721859
    huluk
    Level 32  
    Calibration is described in the first post, at the beginning of the thread!
    After unpacking the new tester, a calibration should be performed, we do this by connecting 1-2-3 leads with the minimum resistance (eg with two jumpers from a silver or unnecessary resistor terminals). We press the microsite and the calibration starts, 38% will be asked to remove the jumpers, to connect 82% to the leads 1-3 previously prepared capacitor with a capacity greater than 100nF.
  • #325 16721863
    wojtek1234321
    Level 36  
    Here: https://www.elektroda.pl/rtvforum/topic3354445.html "After unpacking the new tester, it is necessary to carry out the calibration, we do it by connecting 1-2-3 outputs with the minimum resistance (eg with two jumpers from silver or unnecessary terminals of resistors) We press the microsite and the calibration starts, 38% will be asked to remove the jumpers, to connect 82% to the leads 1-3 previously prepared capacitor with a capacity greater than 100nF. "
  • #326 16721864
    398216 Usunięty
    On disconnected power supply, pins 123 close, turn on the power and press the button. Then follow the instructions on the screen. Anyway, the description is on YT in some tutorial. I do not know (I did not calibrate either - I checked that it was measuring correctly, so I decided it was unnecessary) if this model calibrates too. A friend of mine last ... :)
  • #327 16721882
    E8600
    This tester has a slightly different tile shape than the gadget, so it can have different leads.
  • #328 16722316
  • #329 16722349
    CMS
    Affirmative. Placing in the tester, a damaged element with three pins, which is a permanent short circuit (transistor, double diode), or short circuit "per mile ohms", initiates the calibration.
  • #330 16722503
    rafcio_21
    I agree that with a damaged component (compact) the tester treats as starting calibration, it is quite annoying, but if we put in a new softa, this problem does not occur. We decide ourselves when we want to calibrate it by entering the extended menu and selecting the calibration option.
✨ The LCR-T4 electronics components tester based on the ATMega328 microcontroller is a versatile, low-power device powered by a 9V battery, drawing 12-15mA during measurement and 20nA in sleep mode. It automatically detects component types and lead configurations, measuring parameters such as resistance, capacitance (up to 47,000µF), inductance, diode voltage drop, transistor type and pinout, and ESR. Calibration involves shorting the test leads and using a known capacitor above 100nF. The tester supports testing of discrete components including resistors, capacitors, diodes, bipolar and field-effect transistors, and thyristors, though it struggles with integrated LM series voltage regulators due to their complex internal structures. Accuracy is generally sufficient for amateur and workshop use, with some noted measurement deviations, especially in low resistance and inductance readings. The device features a white LCD display, with some users comparing it to yellow LCD variants and color display models with built-in batteries. The ZIF socket is a known weak point, prone to contact issues and limited to thin leads; users recommend alternative housings and socket modifications for durability. The ribbon cable connecting the display is fragile and non-replaceable separately, requiring careful handling. The tester is available as a DIY kit with open-source firmware and as ready-made units, purchasable from Chinese suppliers and local Polish sellers, with prices around $30 or 25-40 PLN depending on housing and shipping. Shipping damage to displays has been reported due to insufficient packaging, prompting suggestions for improved protection. Firmware variations exist, affecting features like contrast adjustment and component recognition. The device is highly regarded for its ease of use, broad functionality, and value for money, making it a popular gadget among electronics hobbyists. Community discussions include suggestions for further development, housing designs, and integration of the elektroda.pl logo for uniqueness.
TL;DR: LCR-T4 auto-tests 14 part types, draws only 12-15 mA per measurement, and “will be useful in every workshop” [Elektroda, TechEkspert, post #16556695] Accuracy stays within ±2 % for most resistors. Firmware flashing adds live-scan mode and Zener tests. Why it matters: you get multimeter-level insight from a €10 gadget.
• Supply: 9 V battery; 12-15 mA active, 20 nA sleep [Elektroda, 16556695] • R range: 0.1 Ω – 50 MΩ, C range: 25 pF – 100 000 µF, L range: 0.01 mH – 20 H [Elektroda, 16556695] • Typical accuracy: ±1 % R, ±3 % C, ±5 % L (user tests) [Elektroda, 16556695] • ESR read-out for electrolytics ≥1 µF [Elektroda, post #16556695] • Open-source firmware: AVR-based, 40 V boost for Zener mode [Elektroda, 16666684]
1. Which components does the LCR-T4 recognise?
It auto-detects resistors, capacitors, inductors, diodes (single & dual), LEDs, Zener diodes (≤30 V with updated firmware), BJTs, MOSFETs, JFETs, IGBTs (basic), thyristors, triacs, and voltage regulators [Elektroda, #16556695; #16666684].
2. How accurate are its measurements versus a quality multimeter?
User comparison showed 9.97 kΩ read as 10.18 kΩ (2 % high) and 100 µF read as 99.6 µF (0.4 % low) [Elektroda, 16556695] Inductance errors rise above 5 % near the 0.01 mH limit.
3. How do I calibrate the tester?
  1. Short pins 1-2-3 with low-resistance wire.
  2. Hold the single button until “Self-Test” appears.
  3. At 38 % remove jumper; at 82 % connect a >100 nF capacitor between 1-3 [Elektroda, 16556695]
4. What battery life can I expect?
A 550 mAh alkaline 6F22 supports roughly 30 000 tests (≈15 mA × 2 s each); users reported >2 years on one cell [Elektroda, bestler, post #16671201]
5. Why does my inductor show "resistor"?
The MCU flags coils below 0.01 mH or above 20 H as resistive. Bifilar wound or high-resistance windings can also be misread [Elektroda, 16708279]
6. Triac appears as NPN—faulty?
Not necessarily. High-gate-current triacs (e.g., KT207) may be detected as NPN when pin order flips. Confirm by testing both 180° rotations [Elektroda, 16585086]
7. What gains do I get from flashing new firmware?
Newest Git build adds: live-scan (continuous R/C/L), PWM & frequency generator, Zener/IR-LED test to 30 V, Polish UI, and logo support [Elektroda, 16666684]
8. How do I flash the AVR safely?
Use an ISP programmer, set fuses: LOW 0xE2, HIGH 0xD9, EXT 0xFC. Backup the factory hex first; then write the compiled .hex, verify, and power-cycle. Full guide in forum post #16666684.
9. Can I measure ESR in-circuit?
Yes for electrolytics ≥1 µF. Testers showed identical ESR values before and after desoldering PC-motherboard caps [Elektroda, Dydelmax, post #16669734]
10. What’s an edge-case the tester fails?
Charged capacitors can kill the input; one user cracked the LCD after a 50 V part was connected [Elektroda, 16579821] Always short large caps first.
11. How do I protect the ribbon display?
Stick 1 mm foam tape under the LCD and avoid flexing the gold ribbon. A clear acrylic case with 10 mm standoffs prevents pressure on the button [Elektroda, 16674114]
12. How do I assemble the acrylic enclosure?
Follow this 3-step: 1. Sandwich PCB between 10 mm spacers; 2. Insert LCD through front panel, secure with nuts; 3. Add rear plate and eight M3 screws [Elektroda, 16658664]
13. Why does the tester mis-show varicaps?
It measures junction capacitance at one bias only, so it logs them as ordinary diodes. A manual curve-tracer is needed for full C-V plots [Elektroda, 16689532]
14. Where can I buy or what’s the typical cost?
Ready-made LCR-T4 kits ship from AliExpress or eBay for €8–12; Polish stock adds ~40 % markup [Elektroda, 16567602] Shipping weight fits <2 cm letter rate.
