  • A cheap LSC Smart E27 806lm CW bulb from Action was opened, identified, and flashed for local control.
  • The bulb uses a BK7231T chip, with clearly marked TX/RX pads on the PCB and PWM outputs for cold and warm white channels.
  • It cost about 4 euro in the Netherlands, under article number 3000272, and the author mapped pin 24 to CW and pin 16 to WW.
  • After flashing, it appeared correctly in the Home Assistant GUI, and the bulb was reassembled by gluing the transparent top back on.
  • Disassembly takes patience and a steady hand; prying the shell, removing glued boards, and soldering tiny TX/RX pads can damage the bulb if rushed.
  • A very cheap E27 smart bulb. Bought at Action store at around 4 euro in NL, article number 3000272.
    Overall quality is good enough considering the item price. I use it in hallways, storage room, toilet etc.
    LSC Smart E27 806lm CW - BK7231T LSC Smart E27 806lm CW - BK7231T
    Opening the light is pretty easy. If you have some experience opening devices, you can easily pry it open en glue it back together without damage.
    I use a 9mm thin blade, see picture. Slide the blade between the 'transparent' plastic and the base of the light. And keep turning the bulb in your hand, while you use the other hand to push the blade further into the bulb. It might take some time and force before you notice the top of bulb will loosen up. Just try to tilt the transparent piece after every other turn. Eventually it will separate from it's base.
    When you've separated the bulb. You have to remove the LED board. Remove the glue around the board with a screwdriver and a sharp blade. I use a little metal hook that I've bend into an L-shape to pull out the LED board. Keep removing glue until it will pop out. Pull it out straight otherwise you'll damage the pins that hold the board to the base of the bulb.
    Finally, remove the metal cap at the bottom of the bulb with a sharp balde or screwdriver. It's not screwed in or glued, just pull it out.
    You'll see a little metal wire. Carefully bend it to the center of the bulb, into the hole.
    Now that you've loosen the the metal wire at the bottom. You can pull out the main PCB of the bulb a little bit, for 5 to 10mm.
    When the sticker on the chip is removed. I found a BK7231T.
    On the bottom of the PCB you'll find the pins you need for flashin. They are clearly marked. The TX and RX are small but with a steady hand and your soldering iron, you'll manage to attach some wires.
    Flash it with your USB UART flashing device and set pin 24 as PWM value 4 (CW) and pin 16 as PWM value 5(WW).
      - platform: mqtt
        unique_id: "obk06B22AC7"
        command_topic: "cmnd/obk06B22AC7/led_enableAll"
        state_topic: "obk06B22AC7/led_enableAll/get"
        availability_topic: "obk06B22AC7/connected"
        payload_on: 1
        payload_off: 0
        brightness_command_topic: "cmnd/obk06B22AC7/led_dimmer"
        brightness_scale: 100
        brightness_state_topic: "obk06B22AC7/led_dimmer/get"
        brightness_value_template: "{{value}}"
        color_temp_command_topic: "cmnd/obk06B22AC7/led_temperature"
        color_temp_state_topic: "obk06B22AC7/led_temperature/get"
        retain: false
    This is the YAML configuration I use in HA.
    The light shows up as I expect in the HA GUI.
    Put everything back together in reverse order. Glue back the transparent top of the bulb, and you're done.
    Happy flashing!
    Tych0
    Tych0 wrote 15 posts with rating 20. Been with us since 2022 year.
  • #2 20138609
    Very nice teardown! I also have seen Action stores in Poland. This bulb is very cheap as well in my country, it's for about 15 PLN (Polish Zloty).
    By the way, it might be possible to flash this bulb without opening the case:
    https://github.com/tuya-cloudcutter/tuya-clou...9b6e72b28e925379221ae4a6f0078f79/SUPPORTED.md
  • #3 20139647
    Tych0
    Thx. Yes I'm aware of the Cloud Cutter capabilities and for sure it might be able to program your firmware on the device.
    But what's the fun of that :-) I enjoy opening up these devices desolder modules (if needed) and programming better firmware as a hobby.
  • #5 20144036
    ACCel
    Thanks for more information, they have a set of 3 garden lamps RGB + W for PLN 89, which is quite a nice price, they also have a smart spotlight with a motion sensor. You will have to find a store nearby and test it.
    Heh, I did not expect elektroda has some auto translation features :)
  • #6 20144322
    Let me know when you buy, photos from inside / tearedown topic is also well known, maybe even a small gift from Electrode could be found for you.
    I am curious how this motion sensor works, but it will probably also be able to run.
    And autotranslate is, although it does need some manual corrections.
  • #7 20144426
    gulson
    System Administrator
    If you can do a teardown of what's in Action, I'll send you some electrode gifts :)
    Thank you!
  • #8 20145773
    pitron
    If someone does not want to flash, he can integrate this bulb via tuya, you have to build a project on iot.tuya.com. and add it in the tuya app will detect it without any problem. Apparently, the lsc app is a tuya clone.
    PS
    I use at Home Assistant with lsc rgb bulbs, sockets, sirens and garden lamps.
  • #9 20203263
    C0br4
    I'm buying this bulb a lot and it always came with a esp8266 which I quickly flashed to tasmota. Now they silently changed the chipset to BK7231T and I thought I have to buy much more expensive bulbs to still use opensource software. Luckily i found a worthy replacement firmware that runs on these chips, I was just missing the pin config. Happy that I found it finally, thanks alot.
    I have a spotted a small typo though. You write pin 16 is PWM, I think it should be 26.
  • #10 20205074
    It is indeed 26. The pin 16 does not even support PWM function.
    Why do you think they "silently changed the chipset to BK7231T"?
  • #11 20205154
    C0br4
    My guess would be cost reduction, probably the Beken chips are a few cents or fractions of a cent cheaper than the Espressif chips
  • #12 20205584
    gulson
    Maybe it's about licensing problems?
  • #13 20207356
    TheExperimentator
    Thanks for the nice writeup!
    Since I bought the same ones (3000272-970716) also in NL my small comment is that flashing directly using Tuya Cloudcutter works perfectly so no need to open the bulb anymore!
    There is one difference in my setup because I have to use: Pin 24: PWM 1, Pin 26: PWM 2.
    With your I cannot control the bulb at all, was there some other PWM's you set?
    Thanks for MQTT config! Works perfectly.
  • #14 20256778
    starfelicious
    Hi there, i have a very similar bulb, 2000273 instead of 2000272 - it's basically the same bulb but with 1400 instead of 800ish Lumen...
    After some searching around, from what i gather on the tasmota website for reference, the pin numbers etc seem to be exactly the same for these two.
    3000272 = https://templates.blakadder.com/lsc_smart_connect_3000272.html
    3000273 = https://templates.blakadder.com/lsc_smart_connect_3000273.html
    So i managed to do the flash properly, the device is running smoothly on OpenBK, however i cannot get the bulb to do anything for the life of me. I have tried some different combinations of configs. I tried the exact settings as the opening post (P24 = PWM = 4, and P26 = PWM = 5)
    as well as your suggestion of setting PWM to 1 and 2. No results.
    Any chance youd have an idea what else i can try here? It seems i'm well under way seeing i succesfully got OpenBK running on the bulb..just now to get it to actually turn on ^^
  • #15 20256810
    Beken chips have 6 possible PWM pins. Have you checked them all? Is your device CW?
    If none of PWM combinations are working, then you might have a bulb with a dedicated LED driver chip with a variation of I2C protocol.
  • #16 20256839
    starfelicious
    Yes, it's a CW device...
    I did notice this as well, the config page states that "BK7231N/BK7231T supports PWM only on pins 6, 7, 8, 9, 24 and 26!"
    How would i go about testing the other 'pins' ...do i use the exact same values for the pins in combination with the PWM value?
    Sorry if i'm asking daft questions, i'm kinda new to this OpenBK stuff ^^
  • #17 20256904
    Well... the simplest way... would be to try setting 6, 7, 8, 9 24 and 26 to "Relay" role and give each of them a separate channel, 6 will be channel 0, 7 channel 1, 8 channel 2, 9 channel 3, 24 channel 4, 26 channel 5... of course remove all PWMs. Then try enabling channel 0 (on WWW GUI)... see if anything happens... then try enabling channel 1... etc etc....
    NOTE: do not enable all channels at once, because in some rare cases (like RGBCW bulbs) turning all colors 100% bright may overheat LEDs.
  • #18 20256926
    starfelicious
    Aaaah, i see what you did there. That actually got me somewhere...
    Turned out, 7 and 8 (once on channel 1 and 2) did the trick. One switched on full white, the other switches on full warm/yellow.
    Removed all the others, and worked with 7 and 8 only on channel 1 and 2. That worked however the controls seemed reversed (warm = cold, cold = warm) ...so i changed it to:
    So basically reversed the channels, and VOILA , everything works as expected!!
    I'm learning here, thanks a lot man for your swift and VERY helpful feedback...
  • #19 20342453
    piotrdobron
    Hey, I uploaded to the bulb 1.12.19 on the AP everything works perfectly.
    After adding to the HA generated yaml by OPENBK, I can't do automation on this bulb.
    Bulb not showing in devices. Is it possible to add it by Mosquitto broker so that it searches for devices and entities at once?
  • #20 20345844
    @piotrdobron which HA version? Maybe you need to add Unique ID or Entity ID?
  • #21 20346052
    piotrdobron
    Dziękuję za podpowiedz.
    Po wgraniu OpenBK7231T_UA_1.15.213 wszystko zaczęło działać aż miło tylko z PWM inne ustawienia niż w tutorialu!
  • #22 20658072
    daPaulus
    Thanks for the article! I can confirm that this method still works for the Action LSC White ambiance in the new box, I flashed it with OpenBK7231T_UA_1.17.182.bin.
    Except for one thing:
    I had to select P24 PWM channel 1 and P26 channel 2, otherwise the lamp stayed off.
    Just so you know.
✨ The discussion revolves around the LSC Smart E27 806lm CW bulb, purchased inexpensively at Action stores in the Netherlands and Poland. Users share experiences regarding the bulb's quality, ease of disassembly, and potential for firmware modification. The bulb features a BK7231T chipset, which has replaced the previously used ESP8266, prompting discussions about flashing firmware using Tuya Cloudcutter and OpenBK. Users report successful modifications and configurations for PWM control, with specific pin settings required for proper functionality. The conversation also touches on the availability of similar products and the integration of the bulb with home automation systems like Home Assistant.
TL;DR: For under €4 you can unlock and local-control the 806 lm LSC Smart E27 bulb in about 5 minutes; “Very nice teardown!” [Elektroda, p.kaczmarek2, post #20138609] Why it matters: open firmware ends cloud lock-in and extends hardware life.
• Output: 806 lm cool-white, 2700–6500 K range [Elektroda, Tych0, post #20138269] • Chipsets: latest stock = BK7231T/N; earlier batches used ESP8266 [Elektroda, C0br4, post #20203263] • Flash paths: UART pads or 2.4 GHz Tuya-Cloudcutter OTA (≈3 min) [Elektroda, TheExperimentator, post #20207356] • PWM-capable pins: 6, 7, 8, 9, 24, 26 (6 total) on BK7231T [Elektroda, p.kaczmarek2, post #20256810] • Store price: €3.99 NL / PLN 18 in PL (Aug 2022) [Elektroda, Tych0, #20138269; gulson, #20141410]
Which microcontroller is inside the current Action LSC Smart E27 806 lm bulb?
Most 2022-2023 units ship with a BK7231T Wi-Fi SoC once covered by a sticker [Elektroda, Tych0, post #20138269]
What if I prefer the traditional UART method?
Solder to the marked 3.3 V, GND, TX, RX pads, pull the board 5–10 mm out, and use 115 200 bps with 3.3 V USB-UART [Elektroda, Tych0, post #20138269]
Which pins drive cool-white and warm-white LEDs?
Common working map: P24 → PWM 1 (cool-white) and P26 → PWM 2 (warm-white) [Elektroda, daPaulus, post #20658072] Some early guides used PWM 4/5; if the lamp stays dark, swap channels.
How can I quickly find the right PWM pins?
  1. Set pins 6, 7, 8, 9, 24, 26 to “Relay” with distinct channels. 2. Toggle channels one by one in the web UI. 3. Note the two that light cool and warm, then switch them back to PWM roles [Elektroda, p.kaczmarek2, post #20256904]
What happens if no PWM pin lights the LEDs?
A minority of CW bulbs use an I²C LED driver; PWM mapping will fail. You will need to sniff I²C traffic or keep the factory firmware [Elektroda, p.kaczmarek2, post #20256810]
Is Tuya integration still possible without flashing?
Yes. Create a project on iot.tuya.com, pair in the Tuya app, then add the Tuya integration in Home Assistant [Elektroda, pitron, post #20145773]
Does flashing affect Home Assistant discovery?
OpenBK 1.15+ auto-generates MQTT-discovery YAML with unique IDs, so the bulb appears under Devices instantly in HA 2022.11 and newer [Elektroda, piotrdobron, post #20346052]
How do I OTA-flash with Cloudcutter?
  1. Put the bulb in EZ-mode pairing (power-cycle 3×). 2. Run Cloudcutter with the LSC-E27 profile; wait for “Exploit success”. 3. Upload OpenBK or Tasmota BIN via the web uploader created by the exploit. It takes about five minutes total.
What firmware version is recommended today?
OpenBK 1.17.182 adds MQTT auto-discovery and stable PWM timing on BK7231T; users confirm full functionality with the LSC E27 [Elektroda, daPaulus, post #20658072]
