Action LSC 3202086 Addressable LEDs flashing with OBK for control cloudfree like in Tasmota/Esphome
p.kaczmarek2 5217 17
  • #1 21101486
    Packaging of LSC Smart XXL LED Strip featuring a spiral LED light and mobile app.
    LSC 3202086 LSC Smart Connect XXL LED strip is a individually addressable (WS2812B-like) LED strip with extra two PWM channels (RGB + CW).
    LSC Smart Connect LED Strip packaging Packaging of LSC Smart Connect XXL 10m RGBIC + CCT LED Strip Packaging of the LSC Smart Connect XXL LED Strip with product information printed on it.
    It is using BK7231N module, so you can flash it with OBK: https://github.com/openshwprojects/OpenBK7231T_App
    You can check our flashing guides for more info on flashing Beken chips: https://www.youtube.com/playlist?list=PLzbXEc2ebpH0CZDbczAXT94BuSGrd_GoM
    Brandname: LSC
    Product description: LSC Smart Led Strip 1x10m RGBIC + CCT
    EAN Code: 8712879158363
    Product code: 3202086 (factory model number: LS-DCCT-IWD-B-24-10 / LS-DCCT-IW-DB-0.5)
    OBK Device template:
    Currently you also need to manually configure WS2812B-style LEDs, see related topics:
    OpenBeken WS2812B animations - new HTTP panel integration, PixelAnim driver
    The CW + RGB integration will be supported soon in next OBK releases, so it's possible that by the time you read it, it will work out of the box.
    Here is also device description as text:
    Device name seems to be 3202086 XXL LED Strip v1.0.18
    Device manufacturer seems to be LSC
    - LED Cool (Channel 4) on P9
    - LED Warm (Channel 5) on P24
    - WS2812B/SM16705B out on P17
    - Control Pin (TODO) on P6
    - Pair/Toggle All Pin on P7
    This should be enough to get you started with this device, more to come soon. Feel free to ask if you have any questions.
  • #2 21101992
    UPDATE: RGB IC + CW PWMs tested and working in simulator:
    https://www.elektroda.com/rtvforum/topic4057187.html#21101720
    Simulation of configuring RGB IC LEDs with dual PWM on a computer screen. Simulator interface controlling RGB IC and PWM lighting with LED animations. LED lighting simulation with control settings.
  • #3 21327507
    snakesrules94
    Hello there !
    Do you have success with this led strip ?
    I bought one yesterday, did a backup , extract config , but no way to get some light after flashing ...
    Here is my extract :
       "Jsonver":"1.0.5",
       "brightmin":"10",
       "gmwb":"75",
       "title20":"0",
       "cdtime1":"60",
       "1err":"40",
       "cdtime3":"180",
       "cdtime2":"120",
       "totallen":"1000",
       "gmwg":"70",
       "knum":"1",
       "leaderr":"15",
       "wfcfg":"spcl_auto",
       "colormin":"10",
       "bitseq":"0",
       "pmemory":"1",
       "gmkb":"60",
       "pairt":"180",
       "cmod":"rgbcw",
       "slidemod":"2",
       "micpin":"23",
       "customcode":"00ff",
       "rstbr":"50",
       "ktime":"5",
       "0err":"70",
       "colormax":"100",
       "c_pin":"6",
       "module":"CBU",
       "ctrl_lv":"1",
       "rstmode":"2",
       "irpin":"26",
       "brightmax":"100",
       "sfunc":"1",
       "key_lv":"0",
       "wfct":"3",
       "pwmhz":"1000"
    - Microphone (TODO) on P23
    - LED Cool (Channel 4) on P6
    - IR Receiver is on P26
    - PWM Frequency 1000
    Device seems to be using CBU module, which is using BK7231N.
  • #4 21327560
    So how did you configure the PixelAnim driver? What is your autoexec.bat?
  • #5 21327607
    snakesrules94
    hello,
    i didn't start yet to have colour leds. I'm just trying right now to have cool/warm white working. I have no autoexec.bat right now.
    BTW, i've also tried the esphome/libretiny port for this led strip and i also have no light at all, no white, no colours.
  • #6 21327629
    We need more information and you need to try the RGB. Maybe they have now alternate CW control, where second pin is used to control brightness. Try playing with GPIO Doctor on PWM pins. Make some detailed photos, what is connected where?
  • #7 21327635
    snakesrules94
    I think the game is over for now .. I don't have power any more to the board. I have 24V on input but the board is not powered, thinking something went wrong.
    The BK7231N is ok when powered directly from pin but not when powered from the 24V power supply.
  • #8 21327640
    Maybe it's just a mechanical damage. Can you check where voltage reaches and where it doesn't? How the step down converter looks like?
  • #9 21336832
    Dratii
    Hello, I can relate to the snakesrules94 posts.
    and
    and I can't get any LED's to light up
  • #10 21336875
    Can you share 2MB Tuya flash dump so I can try flashing it to my device and check the protocol on the scope?
  • #12 21336886
    Thank you, can you also share some photos of the device inside?
    Have you tried to run PixelAnim driver, as in the first post?
    Related guide: https://www.elektroda.com/rtvforum/topic4057187.html
  • #13 21336912
    Dratii
    Here are the photos of the insides:
    Image of a green circuit board with various connectors and pin labels. Electronic board with several colored wires connected at the top.
    and on the box there is .1 at the end of product code so i guess that means it's a new revision Energy label for LSC Smart Connect product with energy class F.
    I didn't run PixelAnim driver because I have no clue what pins are relating to rgb led's and/or CW
  • #14 21336982
    We actually know which pin is used for LED RGBs, the ones that are per-pixel addressable. It's always P16, hardware SPI output. That's because hardware SPI is used to control the WS2812 LEDs.
    For a start, I'd suggest following PixelAnim/WS2812 topic (linked few posts above) and trying to get some RGB light.
    I would also check if 24V is present on LEDs, because some devices might have extra pin used to toggle power on and off for them, sometimes to dim them. Check it with multimeter.
    Probably the transistor between 24 in and out is used:
    View of a circuit board with marked INPUT 24V locations and labels OUT and a question mark on other pins.
    If there is 0V at output of transistor, try setting each pin in GPIODoctor to 1 and observe which enables voltage for the strip. It will be probably one of PWM pins.
  • #15 21337021
    Dratii
    the 24V on the LED's is present but after using this RGB code in autoexec.bat form PixelAnim thread:
    i didn't get any leds to light up and i tried toggling it on and off using the button in the home menu
  • #16 21337134
    Level 36  
    >>21336881
    which when put into the importer wholesale give you some bits:
    Comparison of JSON configuration with script code for a Tuya device.
    that doesn't match the EF extractor though, which you've already posted
    I think a more complete template would be with this:
    still, your RGB should be working though I would have thought
    Added after 6 [minutes]:
    paired, the 3202086.1 is referred to as LSC Smart Led Strip 1x10m RGBIC + CCT by Tuya
  • #17 21358222
    xpeng
    For the people that have the revision of this product (3202086.2), here is my esphome config and the pinout that I figured out.
    light:
      - platform: cwww
        cold_white: output_cw
        warm_white: output_ww
        cold_white_color_temperature: 6500 K
        warm_white_color_temperature: 2700 K
        on_turn_on:
          - light.turn_off: color_light
      - platform: beken_spi_led_strip
        pin: P16
        chipset: WS2812
        num_leds: 40
        rgb_order: RBG
        power_supply: led_power
        effects:
         - random:
         - pulse:
         - strobe:
         - flicker:
         - addressable_rainbow:
         - addressable_color_wipe:
         - addressable_scan:
         - addressable_twinkle:
         - addressable_random_twinkle:
         - addressable_fireworks:
         - addressable_flicker:
        on_turn_on:
          - light.turn_off: white_light
    output:
      - platform: libretiny_pwm
        pin: P9
        pin: P24
    power_supply:
        pin: P6
    remote_receiver:
      pin:
        number: P26
        mode:
          input: true
          pullup: true
      dump: all
    binary_sensor:
      - platform: gpio
        pin:
          number: P7
          inverted: True
          mode:
            input: True
            pullup: True
        on_press:
          - light.toggle: white_light
    The power supply config needs a bit adjustment (need to add delay to the led when it starts)
    Electronic module with visible components and colored traces
  • #18 21362240
    matiserv4
    For those who has LSC 3202086.1 (i belive it is the same as of @Dratii), i modified config for esphome based on @xpeng config
    Here is how it looks
    bk72xx:
      board: generic-bk7231n-qfn32-tuya
    light:
      - platform: cwww
        on_turn_on:
        pin: P16
        chipset: WS2812
        num_leds: 40
        rgb_order: RBG
        effects:
         - random:
         - pulse:
         - strobe:
         - flicker:
         - addressable_scan:
        on_turn_on:
    output:
        pin: P6
        pin: P24
    power_supply:
        pin: P22
    remote_receiver:
      pin:
        number: P26
        mode:
          input: true
          pullup: true
      dump: all
    binary_sensor:
      - platform: gpio
        pin:
          number: P20
          inverted: True
          mode:
            input: True
            pullup: True
        on_press:
The discussion focuses on the LSC Smart Connect XXL LED strip (model 3202086), an individually addressable RGBIC + CCT LED strip based on the BK7231N chip, compatible with OpenBK7231T (OBK) firmware. Users share experiences flashing the device with OBK and ESPHome, aiming to achieve control similar to Tasmota/ESPHome for cloud-free operation. Key challenges include configuring the PixelAnim driver for WS2812B-like LEDs on hardware SPI pin P16, managing additional PWM channels for cold/warm white (CW) LEDs, and ensuring proper 24V power delivery through onboard step-down converters and transistor switches. Several users provide JSON device configurations extracted from Tuya firmware, highlighting pin assignments: microphone on P23, IR receiver on P26, CW LED on P6, and RGB LEDs on P16. Attempts to light the LEDs using PixelAnim and SM16703P drivers initially failed, prompting suggestions to verify power lines and PWM pin control via GPIO Doctor. Later contributions include ESPHome YAML configurations for both 3202086.1 and 3202086.2 revisions, demonstrating working setups with beken_spi_led_strip platform for RGB LEDs and libretiny_pwm outputs for CW channels, enabling various lighting effects and proper color temperature control. The thread also includes requests for Tuya flash dumps and internal device photos to aid in protocol analysis and hardware understanding.
Summary generated by the language model.
