Implementing Variable Time Calculations for OpenBeken's addClockEvent Function
ilengyel 2088 12
  • #1 20920436
    ilengyel
    I would like to create a clock event based on a calculated variable, but finding it might not be possible with the current code. I see the default tokenizer settings only allow single complete constant expansions. For example,
    addClockEvent 22:34 $ch13 1 echo daysExpanded
    is okay, but
    addClockEvent $ch14:$ch15 0xff 2 echo timeExpanded
    addClockEvent $ch14 0xff 3 echo timeExpanded
    are not okay.
    I see 2 options:
    1. Enable TOKENIZER_ALTERNATE_EXPAND_AT_START flag for the add clock event's string tokenizer. This would allow a script like
    setChannel 14 $hour+1
    setChannel 15 $minute+45 // does not handle minute overflow
    addClockEvent $ch14:$ch15 0xff 4 echo timeExpanded
    2. Allow a single integer value for the time parameter that would represent a TimerSeconds type from midnight. This would allow a script like:
    setChannel 10 $sunset+1800
    addClockEvent $ch10 0xff 5 echo timeExpanded
    Personally, my preference is the second option since the time calculations and comparisons are a lot easier when they are a single integer, but I understand there will be a few quirks in the second option:
    addClockEvent 7 0xff 6 echo Triggered7SecondsAfterMidnight
    addClockEvent 7:00 0xff 7 echo Triggered7am
    addClockEvent 7:00:00 0xff 8 echo AlsoTriggered7am
    addClockEvent sunset 0xff 9 echo TriggeredCorrectSunsetEveryDay
    addClockEvent $sunset 0xff 10 echo TriggeredAtTheSameTimeEveryDay
    I can be convinced for the first option if there is an easy way to extract hours and minutes from a TimerSeconds type. I am not seeing a way currently since evaluate expression treats everything as a float and there is no MOD operator, which I suspect is also due to only float.
  • #2 20923004
    This is a good idea in general, but the approach 1 would break other scripts, because expanding all variables would also expand everything in the event body, for example:
    addClockEvent $ch14:$ch15 0xff 4 setChannel 5 $CH10
    This will expand $CH10 at the addClockEvent execution time.
    For your idea 1 to work, we would need to have ability to choose what is being expanded. I can indeed see an advantage of being able to set both hours and minutes separately, but it would require some thinking how to handle it in the OBK.
    Idea 2 is simpler, but not as much as flexible as idea 1, when done correctly.
  • #3 20924564
    ilengyel
    I would contend that option 2 would be the more flexible option. Mainly because with option 1 I am not sure how to implement "setChannel 15 ($minute+45)%60" without a modulus operator. With option 2 I would just have to convert a time to seconds. I have a PR ready to go for option 2 at addClockEvent - allow TimerSeconds #1045 which I have tested to confirm that the handler's constants are not expanded like the first 3 arguments are. I.e.:
    addClockEvent $CH10 0xff 5 echo Light ON at $CH10
    listClockEvents
    // Gives the following result
    // Info:CMD:Ev 5 - 20:35:0, days 0xff, cmd echo Light ON at $CH10
    Having said that, the 2 options are not exclusive, and I would like to raise a separate PR for option 1. It just requires a bit of digging into the AddClockEvent/TokenizeString code. My current set of observations in that area are:
    Enable TOKENIZER_ALTERNATE_EXPAND_AT_START flag for the TokenizeString method would allow for $hour:$minute notation
    Tokenizer_GetArg is used for the first 3 arguments, which underneath takes the expanded arguments stored in the g_args array
    Tokenizer_GetArgFrom is used for the handler command which takes remaining unexpanded arguments from specified index stored in the g_argsFrom array
    There is a problem in the Tokenizer_TokenizeString(..) function around the line g_argsFrom[g_numArgs] = (s+(p-g_buffer)); where s is the unexpanded buffer, and p-g_buffer is the offset for the current argument in the expanded buffer. This would only work if all the constants' names have the same string length as their corresponding value string length eg $CH10 -> 12345
    Changing the TokenizeString function is a bit scary since it would affect almost all commands
  • #5 20931598
    Sorry for the delay, I will try to look into it more in depth later, but in general I'd like to have module operator and braces support. I may look into it tonight, if that can help.
    If you are able to run Simulator, you can prepare some more self-tests before your changes, add them separately as a pull request so i can review them, and then we can try to improve tokenizer without breaking compatbility
  • #6 20932902
    ilengyel
    If you are able to run Simulator, you can prepare some more self-tests before your changes, add them separately as a pull request so I can review them, and then we can try to improve tokenizer without breaking compatibility
    Yep, I added some new ones in selftest_tokenizer.c and selftest_clockEvents.c. Let me know if some other conditions should be included. The actual code changes for multi expand token support were not that hard either, so I am quite confident about it now.
    In general, I'd like to have module operator and braces support.
    I think this would deserve its own thread. As far as I can tell, all numeric values are floats, and mod on floats is not obvious ... actually, some googling explained it for me: float fmodf(float a, float b).
  • #7 20933043
    I think I will merge your pull request tomorrow, but I will also make sure that everything else is still working. I may push some more self tests first today evening as well.
  • #8 20935893
    I've merged your PR, but I think we need some more docs on this topic. Would you like to write a short tutorial for our tutorials section here about the usage of arguments expansion for clock operations?
    https://www.elektroda.com/rtvforum/forum517.html
  • #9 20936417
    ilengyel
    Yep sure I will write one up over the next few nights. Any particular format is preferred?
    In the meantime here is my ultimate porch light script that this merge enabled for me :)
    PowerSave 1
    startDriver ntp
    ntp_setServer 192.168.1.12
    ntp_timeZoneOfs 11
    ntp_setLatlong <latitude> <longitude>
    logfeature 6 0
    logfeature 7 0
    // Channel 10: maintain sunset time (The time when the light should turn on)
    setChannelLabel 10  "<b><span style='color:orange'\>Light ON (Civil Sunset)</span></b>"
    setChannelType 10 TimerSeconds
    // when using $sunset as an expression in addClockEvent, it needs to be re-calculated every day to take into account different sunset values
    alias calc_sunset backlog setChannel 10 $sunset+1800; removeClockEvent 4; addClockEvent $CH10 0xff 4 high_lights; echo Lights will turn on at $CH10
    // Channel 11: hidden register to store current time as TimerSeconds
    setChannelType 11 TimerSeconds
    setChannelPrivate 11 1
    setChannelVisible 11 0
    // Channel 12: trigger for timer_on_lights
    setChannelLabel 12 "Light Timer"
    setChannelType 12 Toggle
    setChannel 12 0
    alias timer_on_lights setChannel 12 1
    // Channel 13: 3 way toggle for light settings
    setChannelLabel 13 "Switch"
    setChannelType 13 OffDimBright
    alias off_lights setChannel 13 0
    alias low_lights setChannel 13 1
    alias high_lights setChannel 13 2
    // timer trigger: lights will be on high for 5mins, then on low for a further 25mins, then turned off
    addChangeHandler Channel12 == 1 backlog high_lights; addRepeatingEvent 300 1 low_lights; addRepeatingEvent 1500 1 off_lights
    addChangeHandler Channel13 == 0 backlog led_enableAll 0; setChannel 12 0; echo lights_set_off
    addChangeHandler Channel13 == 1 backlog led_temperature 500; led_dimmer 5; led_enableAll 1; echo lights_set_low
    addChangeHandler Channel13 == 2 backlog led_temperature 300; led_dimmer 30; led_enableAll 1; echo lights_set_high
    addClockEvent 3:30 0xff 1 calc_sunset
    addClockEvent 21:00 0xff 2 low_lights
    addClockEvent 23:00 0xff 3 off_lights
    waitFor NTPState 1
    waitFor MQTTState 1
    calc_sunset
    // set the current time as TimerSeconds in register for checks below
    setChannel 11 $hour*3600+$minute*60
    // Set initial light state to match the above clock events
    // sunset - 21:00   lights set to high (evening activities)
    // 21:00 - 23:00    lights set to low (sleepy mode: warmest temperature and very dim)
    // 23:00 - sunrise  lights on for a short period (bedtime the lights should be off, but can be forced on for a period by switching off and on)
    // sunrise - sunset lights turned off (day time the lights should be off)
    if $CH11>=$CH10&&$hour<21 then high_lights
    if $hour>=21&&$hour<23 then low_lights
    if $hour>=23||$CH11<$sunrise then timer_on_lights
    if $CH11>=$sunrise&&$CH11<$CH10 then off_lights
    It has a few extra features which I did not include in the automatic_day_and_night_lights_v3.bat:
    - Light timer function that can be triggered by MQTT on channel 12 or switching the light off and on after bed time
    - Off/Dim/Bright control via MQTT channel 13
  • #10 20936481
    Well, you can look up other topics in the tutorials section, but I don't have any specific requirements in mind. Just try to explain the feature to new users, link to our docs, link to this topic (maybe, for the reference), give some more samples... don't worry about repeating the information that is already somewhere else, I've noticed that beginners sometimes don't like to read "raw docs", they prefer step by step tutorials.
    That's a very nice script, you can add it to autoexec examples if that's not there yet.
  • #11 20942300
    ilengyel
    Finally added the tutorial in the above forum section. Let me know if any clarifications are required.
  • #12 20942539
    That's a nice writeup, but articles require having one image at the start of the text, can you post there something, idk, a screenshot of OBK web panel or something?
  • #13 20942746
    ilengyel
    Updated it to include the web panel of the scenario mentioned in the article.
✨ The discussion revolves around implementing variable time calculations for the addClockEvent function in OpenBeken. The user proposes two options: enabling the TOKENIZER_ALTERNATE_EXPAND_AT_START flag to allow for more flexible variable expansions in clock events, or allowing a single integer value representing TimerSeconds from midnight for simpler time calculations. Responses highlight the potential complications of option 1, particularly regarding variable expansions in event bodies, while option 2 is seen as more straightforward. Several contributors express support for both options, with pull requests (PRs) being prepared for implementation. The conversation also touches on the need for additional documentation and tutorials to assist users in understanding the new features.
TL;DR: After 1 PR merged, OpenBeken’s addClockEvent supports robust, computed scheduling; "I've merged your PR," noted maintainer p.kaczmarek2. For OBK scripters asking how to schedule variable times, use TimerSeconds or multi-variable expansion. [Elektroda, p.kaczmarek2, post #20935893]
Why it matters: It lets you automate lights and scenes at precise, changing times without brittle math or broken handlers.
What changed in addClockEvent after the recent merge?
A pull request was merged to improve clock operations and argument expansion. The maintainer requested a tutorial to guide users, signaling mainline availability. Check the tutorial and examples to adopt the updated usage patterns. [Elektroda, p.kaczmarek2, post #20935893]
How do I schedule a dynamic time using seconds from midnight?
Use the TimerSeconds approach.
  1. Compute seconds: setChannel 10 $sunset+1800.
  2. Schedule: addClockEvent $CH10 0xff 5 echo Light ON at $CH10.
  3. Verify: listClockEvents shows the scheduled time and literal handler. This avoids overflow math and keeps your handler intact. [Elektroda, ilengyel, post #20924564]
What’s the difference between sunset and $sunset in addClockEvent?
Using sunset recalculates daily, tracking the correct astronomical time. Using $sunset expands once at scheduling, so it triggers at the same fixed clock time each day. Choose sunset for drifting daylight, $sunset for a fixed daily time. [Elektroda, ilengyel, post #20920436]
Can I pass $hour:$minute directly to addClockEvent?
Yes, with multi-expand token support you can pass both hour and minute in one go. Example: addClockEvent $hour:$minute 0xff 4 echo timeExpanded. Self-tests were added to validate multi-expansion behavior in tokenizer and clock events. [Elektroda, ilengyel, post #20932902]
Will variables inside the handler expand when I schedule the event?
No. Only the first three addClockEvent arguments expand. The handler body stays literal, so references like $CH10 remain unchanged at schedule time, preventing unintended substitutions. [Elektroda, ilengyel, post #20924564]
Which approach is more flexible—variable expansion or TimerSeconds?
Both are useful. TimerSeconds simplifies math and comparisons. Token-based hour:minute expansion allows finer control of fields. As the maintainer put it, "Idea 2 is simpler, but not as much as flexible as idea 1, when done correctly." [Elektroda, p.kaczmarek2, post #20923004]
What options were proposed for variable time calculations?
Two options were proposed: 1) tokenizer-based multi-expand to allow $hour:$minute; 2) accept a single integer time representing seconds since midnight (TimerSeconds). The author preferred option 2 for easier comparisons and arithmetic. [Elektroda, ilengyel, post #20920436]
How do I avoid minute overflow without a modulo operator?
Skip manual H:M math and use a single seconds value. Without mod, expressions like ($minute+45)%60 are awkward. TimerSeconds avoids overflow edge cases and makes comparisons simpler. Compute once, then schedule with addClockEvent $CHn. [Elektroda, ilengyel, post #20920436]
Is modulo and parentheses support coming to OpenBeken expressions?
Yes. The maintainer stated they want module operator and braces support and planned to look into it. This will simplify time arithmetic and precedence control in scripts. [Elektroda, p.kaczmarek2, post #20931598]
Are numeric expressions floats in OpenBeken?
Yes, contributors observed numeric values are floats. For modulo on floats, fmodf semantics apply. This helps frame how a future mod operator could behave in expressions. [Elektroda, ilengyel, post #20932902]
How can I test tokenizer and clock-event changes safely?
Use the Simulator and add self-tests before changing the tokenizer. Submit tests for review to catch regressions, then iterate on improvements without breaking compatibility. This workflow was encouraged by the maintainer. [Elektroda, p.kaczmarek2, post #20931598]
Could enabling “expand all variables” break my scripts?
Yes. Expanding all variables would also expand variables in the handler command at schedule time. That can alter behavior and break existing scripts unless expansion is selective. [Elektroda, p.kaczmarek2, post #20923004]
Do you have a real-world example I can copy?
Yes. A porch-light automation uses NTP, sunrise/sunset offsets, and staged dimming. It schedules sunset+30 minutes, then night-time low and off windows, with a manual timer trigger. Adapt it to your channels and location. [Elektroda, ilengyel, post #20936417]
Where can I find the step-by-step tutorial?
The author published a tutorial in the project’s Tutorials section. It includes examples and screenshots to help new users apply the features quickly. [Elektroda, ilengyel, post #20942300]
