[Solved] Smok Nord E-Cigarette Flashing Four Times: Potential Causes and Solutions
kazimierz608 47856 2
  • #1 19132773
    kazimierz608
    Please help, I have had the Smok Nord e-cigarette for about a year. The problem is that it flashes four times when the button is pressed. The heater is good just bought, I cleaned the atomizer and the contacts on the battery and nothing helped. The cigarette is loaded. I checked with a multimeter and there is a hissing voltage. What could be damaged and can I fix it somehow?
  • #2 19133247
    Ryder12
    Level 4  
    Take it apart again (the entire atomizer), you may have inserted the heater incorrectly, if that doesn't help, then replace the entire cartridge.
  • #3 19501335
    kazimierz608
    Replacing the cartridge helped, thanks.
