Why is the VAPE PEN 22 not charging and how to fix it?
karpiumaa 16920 3
  • #1 19889657
    karpiumaa
    Hello, I have an e-cigarette vape pen 22 unused for a month and when I wanted to light it, it was discharged, I connected it to the charger under the USB port, the red diode lights up, which means charging, but after half an hour when it should charge at least a little after turning it on 5 clicks 4 times blinking red and not working how to fix it?
  • #2 19889707
    OPservator
    Probably the battery needs to be changed.
  • #3 20146194
    danio260l
    Where can I buy such a battery?
  • #4 20146742
    streamck
    @danio260l look at the manual of this device: https://res.smoktech.com/order/files/1501657276029.pdf
    Battery charging is complete when the red LED turns off. In addition, this equipment has a number of other protections:
    5 flashes of white LED when the power button is pressed for more than 8 seconds - then it cuts the battery.
    4 flashes of the white LED when the resistance (heaters or something, I'm guessing) is too low or too high - then it cuts off the battery output.
    4 white LED flashes when a short circuit is detected - cuts off the battery output then.
    15 flashes of the LED when the battery voltage is less than 3.3V - also cuts off the battery output to protect it from damage.
    In addition, the battery indicator should flash 4 times after each "puff" according to what is written in the manual. Good luck.
