TV Channels: Setting up Antenna for Mux3 Reception - Basic Channels TVP1, TVP2, Polsat, Mux8
FazZi85 11436 13
  • #1 17263535
    FazZi85
    Hello, the problem is that I have a regular antenna on the roof that receives channel 8, i.e. mux8, where there are some tv wp channels, new, metro and 4 test channels, and my point is to receive at least the basic tv channels, i.e. tvp1, tvp2, Polsat, from what I read on the net, you need to receive mux3, before all the confusion with digitization everything was ok, on the old antenna, the so-called with a plate, where it was powered from the power supply at the TV. Currently, I have replaced the coaxial cable with a new one, which was connected to the old analog aluminum antenna lying on the roof, what do you need to set up or do to receive mux3 or at least tvp1, 2, Polsat?
  • #2 17263542
    DiZMar
    FazZi85 wrote:
    ... which is lying on the roof, what needs to be set or done to receive mux3 ...
    First of all, place the antenna in the right direction (towards the transmitter). Lying down is unlikely to pick up. Check if 12V reaches the plate in the antenna and, just in case, replace the board (amplifier). To receive digital channels, you need the same antenna as for analog. It's been almost 5 years since the confusion. Haven't you watched TV during that time?
  • #3 17263579
    FazZi85
    Lying old aluminum antenna on the roof picks up mux8. The mesh antenna (the one with the plate is disconnected from the concentrator) from what I remember, it received many channels, and now the effect is the same as with the old one, so why keep the size large. I even took a new indoor antenna from the store, which also caught the mux8, of course it went to the complaint because it did not live up to what was expected, and I am interested in mux3. It may be necessary to check the plate.
    I haven't watched TV for a long time, but at home one person from time to time tells me that he wants to watch teleexpress, and by the way I would also like to watch a movie or just a match on TV from time to time.
  • #4 17263586
    DiZMar
    You need to mount the same antenna as the neighbors have and similarly attached. If you have a power supply, there should be an amplifier in the antenna box. I don't think you live in the desert :?:
    And of course, run an automatic search for digital channels.
  • #5 17263658
    Prof. SpecMiernik
    You would be surprised how much DVB-T desert there is - it is enough to live next to the forest.
    Running an auto scan is the worst thing you can do.
  • #6 17263664
    DiZMar
    Without programming, even if the antenna was great for all MUXs, the screen will be dark. Of course, it's best to program on a certain antenna.
    Added after 18 [minutes]:
    If Polsat will be there will be the rest of this MUX2, i.e. TVN, TV4, TV Puls, Puls 2, TVN 7, TV 6 and Super Polsat, that is all or nothing from MUX 2
    If there is TVP 1 HD, then also TVP 2 HD, TVP Info HD, TVP Kultura, TVP Historia TVP Sport, that is all or nothing from MUX 3.
    All or nothing from MUX 1 is TVP ABC, Eska TV, Polo TV, TTV, ATM. Entertainment TV Trwam, Stopklatka TV and Fokus TV.
    MUX 8 is all or nothing, i.e. Nova TV, Zoom TV, Metro and WP, and reserve ones.
    It cannot be that there is a program in the given MUX and there are no others.
  • #7 17263831
    _kli_
    FazZi85 wrote:
    Sandomierz
    FazZi85 wrote:
    I'm interested in mux3
    You have the mux-3 transmitter (TVP channels) in Sandomierz, at ul. Mokoszyńska . Using the amplifier near the transmitter may result in no reception.
    What is this antenna?
    FazZi85 wrote:
    what needs to be set or done to receive mux3 or at least tvp1, 2, Polsat ?
    DiZMar wrote:
    If there will be Polsat, there will be others MUX2 that is: TVN, TV4, TV Puls, Puls 2, TVN 7, TV 6 and Super Polsat, that is all or nothing from MUX 2
    The closest transmitter for all muxs (including mux-2) is St. Cross.
  • #8 17264024
    TELMOR_PL
    Level 32  
    This Sandomierz is not a point on the map. What is the exact location of the installation (address, coordinates) and how many receivers will be connected?
    This is the basic information when choosing the right equipment.
  • #9 17265895
    irekr
    I just add that depending on the part of Sandomierz - regardless of the "lighting" MUX3 doing more harm than good - you receive signals from three transmitters: Święty Krzyż - this is for the left-bank part, but without the area on the Vistula itself - but the entire area of the Vistula slope and the whole Zarzekowice and Nadbrzezie are within the range of Leżajsk and Sucha Góra near Krosno. MUX1 and MUX2 from the transmitter on the Holy Cross are basically non-pick up there.
    And how far do you live from Mokoszyńska?
  • #10 17363006
    FazZi85
    DiZMar wrote:
    [...] the same antenna as the neighbors and similarly attached. If you have a power supply, there should be an amplifier in the antenna box. [...]
    I think that the neighbor's antenna is not to be suggested, because it may have a neighbor coax connected to the decoder, also even an ordinary dipole, then it would be enough :P maybe.
    As for the location of the transmitters, I know that it is best to direct to St. Cross, but closer to the chimney in Machów / Tarnobrzeg, but I only catch Mux8 from the antenna.
    Ah, that old aluminum antenna named "Orbit 2" [Russian letters] works fine, it just grabs the entire Mux8. I think that I will attach this earlier mesh antenna with a plate [some small electronics] where the power supply at home and the antenna cable for the TV, together with the aluminum cable, are attached to the cable, and the direction to St. The cross, maybe it will be something of this. Possibly the circuit board [electronics] is damaged or too weak.
  • #11 17363084
    _kli_
    FazZi85 wrote:
    I know that it is best to direct to St. The cross, however, is closer to me chimney in Machów / Tarnobrzeg However, I only catch Mux8 from the antenna
    Tarnobrzeg does not suit mux-2 .
    FazZi85 wrote:
    this old aluminum antenna is called "Orbit 2"
    Is it such antenna? According to technical data is intended for collection k. 21-41. So, from Tarnobrzeg, you should theoretically pick up the mux-3 (sheet 26).
    The grid should theoretically receive k. 21-69, orbit k. 21-41. So why these two antennas for the same transmitter?
  • #12 17363519
    LeDy
    Where did you get these messages from? She picks it up, as already, k. 6-69.
    The author of the topic writes as if he knew everything and I don't know why he founded this topic?
    He doesn't check :D :D hints and argues with them!
  • #13 17363612
    FazZi85
    @_kli_: yes exactly like that :) Of course I wouldn't point two antennas at the same transmitter.
    On the aluminum one I catch mux8 in every direction, I don't understand why I don't catch other muxs. That's why I want to attach one antenna to the other and both to one tv.
    @LeDy: if I didn't check, I wouldn't reply and quote earlier, I just want to solve the problem that there would be programs that I had before this whole revolution with these broadcasting standards.
  • #14 17363616
    _kli_
    Not always and not everywhere. Saint Cross gives mux-8 vertically, and I used the word "theoretically". In practice, it may or may not.
    FazZi85 wrote:
    On the aluminum one, I grab the mux8 in every direction
    Since you receive band III on the band IV antenna, the signal must be very strong. So the more you should catch the mux-8 from Tarnobrzeg on the net and then you don't have to sum the antennas.
✨ The discussion revolves around the challenges of receiving MUX3 channels (TVP1, TVP2, Polsat) using a roof-mounted antenna. The user currently receives MUX8 but struggles with MUX3. Suggestions include ensuring the antenna is correctly oriented towards the transmitter, checking for power supply to the antenna's amplifier, and possibly replacing the antenna with a model similar to those used by neighbors. The importance of running an automatic channel scan and the potential issues with signal interference from nearby transmitters are also highlighted. The user considers combining two antennas to improve reception but is cautioned about the technical feasibility of such an approach.
TL;DR: One local MUX‑3 transmitter serves Sandomierz at ul. Mokoszyńska, and "Using the amplifier near the transmitter may result in no reception." Aim Święty Krzyż for MUX‑1/2; align carefully. [Elektroda, kli, post #17263831]
Why it matters: This FAQ helps Sandomierz‑area viewers reliably receive TVP1, TVP2, and Polsat via DVB‑T without trial‑and‑error.
How do I receive MUX‑3 (TVP1, TVP2) in Sandomierz?
Point a UHF antenna at the local MUX‑3 transmitter on ul. Mokoszyńska. Keep amplification low near this site; “Using the amplifier near the transmitter may result in no reception.” Mount outdoors and align precisely for a clear path. TVP channels are on MUX‑3, so correct aiming is key. [Elektroda, kli, post #17263831]
Which direction should I point the antenna to get Polsat (MUX‑2)?
Aim toward the Święty Krzyż transmitter. It is the closest site carrying all multiplexes, including MUX‑2 for Polsat. Align carefully on that azimuth and secure the antenna to minimize movement. [Elektroda, kli, post #17263831]
Does the Tarnobrzeg Machów chimney broadcast MUX‑2 (Polsat)?
No. That transmitter does not provide MUX‑2, so you will not receive Polsat from Machów. For MUX‑2, target Święty Krzyż instead with a properly aligned UHF antenna. [Elektroda, kli, post #17363084]
Why am I only getting MUX‑8 on my UHF antenna?
Święty Krzyż transmits MUX‑8 in VHF band III with vertical polarization. UHF “grid” antennas target UHF, so VHF reception is inconsistent. As noted, “In practice, it may or may not” work in that configuration. Use an antenna suited to the band and polarization you need. [Elektroda, kli, post #17363616]
Should I use a mast amplifier near the Mokoszyńska MUX‑3 site?
Use caution or avoid it. “Using the amplifier near the transmitter may result in no reception.” Strong local signals can overload active devices. Start passive, verify stable reception, and only then consider amplification if absolutely necessary. [Elektroda, kli, post #17263831]
Is auto‑scan a good idea when setting up channels?
Skip it. “Running an auto scan is the worst thing you can do.” Auto‑scan often pulls unstable or duplicate entries from multiple sites. Prefer targeted setup based on a single chosen transmitter. [Elektroda, Prof. SpecMiernik, post #17263658]
How do I check the mesh antenna’s amplifier plate and power?
Use this quick check:
  1. Verify the 12V power supply output at the TV end.
  2. Confirm 12V reaches the amplifier plate inside the antenna box.
  3. If uncertain, replace the plate (amplifier) and retest reception. [Elektroda, DiZMar, post #17263542]
Can I combine two antennas (e.g., grid and Orbit 2) into one TV?
Avoid combining if both target the same transmitter. As one expert asked, “Why these two antennas for the same transmitter?” Use one correctly aimed antenna per site to reduce losses and interference. [Elektroda, kli, post #17363084]
Do old analog antennas work for digital DVB‑T?
Yes. “To receive digital channels, you need the same antenna as for analog.” Ensure the antenna points to the correct transmitter and the feed electronics work. Replace a faulty amplifier board if needed. [Elektroda, DiZMar, post #17263542]
If I see Polsat, should I get the whole MUX‑2 lineup?
Yes. Polsat is on MUX‑2, which carries eight services together: TVN, TV4, TV Puls, Puls 2, TVN7, TV6, and Super Polsat. “It is all or nothing from MUX 2.” Stable MUX‑2 implies all listed channels decode. [Elektroda, DiZMar, post #17263664]
I live near the forest—why is my DVB‑T unreliable?
“You would be surprised how much DVB‑T desert there is – it is enough to live next to the forest.” Trees and terrain cause blockage and reflections, degrading stability. Raise the antenna and aim at a reliable site for improvement. [Elektroda, Prof. SpecMiernik, post #17263658]
Which transmitters cover different parts of Sandomierz?
Left‑bank Sandomierz tends to use Święty Krzyż, except near the Vistula riverside. The Vistula slope, Zarzekowice, and Nadbrzezie lean toward Leżajsk and Sucha Góra near Krosno. In slope areas, MUX‑1 and MUX‑2 from Święty Krzyż are basically not receivable. [Elektroda, irekr, post #17265895]
What info should I provide before choosing antenna gear?
Share the exact address or coordinates and the number of receivers. “What is the exact location of the installation and how many receivers will be connected?” Sizing antennas, amplification, and splitting depends on that data. [Elektroda, TELMOR_PL, post #17264024]
Do I need to program the TV before anything shows?
Yes. “Without programming, even if the antenna was great for all MUXs, the screen will be dark.” Perform channel setup after the antenna is stable to avoid unreliable results. [Elektroda, DiZMar, post #17263664]
What about MUX‑8 polarization versus my grid antenna?
Święty Krzyż transmits MUX‑8 vertically, while grid antennas are typically used for UHF. This mismatch reduces VHF performance. “In practice, it may or may not” receive MUX‑8, so expect variability. [Elektroda, kli, post #17363616]
