[Solved] Mux8 Reception Issues in Tomaszów Mazowiecki: Mesh Antenna & LNA-169 Amplifier Usage
aconatic 15102 4
  • #1 17205721
    aconatic
    I live in Tomaszów Mazowiecki. I'm using a mesh antenna with 21-69 amplifier, the antenna is directed at Przysuche. I receive Mux1, Mux2 and Mux3 without any problems. This transmitter also offers Mux8, which I do not receive.
    Any ideas what I could change to start receiving Mux8? Is it enough to change the amplifiers to UHF VHF, e.g. LNA-169? I will add that I have 42km to the transmitter.
  • #2 17205750
    use a 5-element VHF antenna with this amplifier as you mentioned I had the same problem, but in vertical polarization this polarization is enough to receive all MUX, because MUX 8 transmits basically with low power
  • #3 17207850
    TELMOR_PL
    Level 32  
    The amplifier in the "grid" is the UHF band, i.e. channels 21-69 as you write, so it will not strengthen the VHF band (174-230MHz), i.e. channels 5-12. Quite suppress them.
    You can replace the amplifier with a two-band (UHF + VHF), the grid will also receive vertical polarization in some conditions.
    If not, then add the VHF antenna + crossover, e.g.
    https://www.telmor.pl/Katalog-produktow/Anteny-naziemne/Anteny-kierunkowe-VHF-DVB-T-DAB
    https://www.telmor.pl/Katalog-produktow/Anten...wrotnice-pasmowe/ZWR-210DC-zwrotnica-antenowa
    or buy an antenna for two bands, e.g .:
    https://www.telmor.pl/Katalog-produktow/Anten...-urbo-T-COMBO-antena-kierunkowa-UHF-VHF-DVB-T
  • #4 17208170
    LeDy
    I suggest (channels 1-60) but I would also give SWA 9001. Mux8 Reception Issues in Tomaszów Mazowiecki: Mesh Antenna & LNA-169 Amplifier Usage and the best is a regulated power supply. If that works well, you don't have to change it.
  • #5 17212061
    aconatic
    The UHF-VHF-DVB-T directional antenna plus a dual band amplifier did the trick.
