Guide to Syncing Polsat Cyfrowy HD3000 Decoder with Older Samsung LCD TV
mentos2017 16056 9
  • #1 17140029
    mentos2017
    I need your help, I want to pair the Polsat Cyfrowy HD3000 decoder with the old Samsung LCD (turning on the TV, changing the volume with polsat remote control). If someone has dealt with this, please help. How to do it?
    I have this pilot
    Remote control for Polsat Cyfrowy HD3000 decoder.
    Thank you in advance.
  • #2 17140116
    maksar
    Define yourself again, only humanly.
    and what is this picture for, you think nobody has seen it?
  • #3 17140242
    andpol 33
    This is not a universal remote control and it is not possible to control the TV, unless the TV supports HDMI-CEC.
  • #4 17140499
  • #5 17140505
    andpol 33
    But the volume can be adjusted in the decoder and then the TV remote to the drawer.
  • #7 17159892
    Olek II
    Moderator
    And what TV will turn on and off?
  • #8 17159895
    andpol 33
    And you haven't heard about HDMI-CEC?
  • #9 17159902
    olekt2002
    mentos2017 wrote:
    I want to pair Polsat Cyfrowy HD3000 decoder with the old Samsung LCD
    Maybe it would be appropriate to provide the TV model?
  • #10 17165580
    pikarel
    mentos2017 wrote:
    I need your help, I want to pair Polsat Cyfrowy HD3000 decoder with old Samsung LCD (turning on the TV, changing the volume with polsat remote control). If someone has dealt with this, please help. How to do it?.
    If the TV already has software with the Anynet / CEC function - run it in the TV menu.
    However, I can't guarantee that Polsat's decoder will control the CEC function on TV, because you haven't even provided the model of this old Samsung.
The discussion revolves around the challenge of syncing a Polsat Cyfrowy HD3000 decoder with an older Samsung LCD TV, specifically for controlling the TV's power and volume using the decoder's remote. Responses indicate that the Polsat remote is not a universal remote and cannot control the TV unless the TV supports HDMI-CEC. Users suggest that while the decoder can adjust volume, the TV remote may need to be used for other functions. The importance of knowing the specific Samsung TV model is emphasized, as it may have implications for compatibility with HDMI-CEC features.
Summary generated by the language model.
