[Solved] Terrestrial TV Signal Lost in New Apartment - Possible Causes, Antenna, Cable Issues
juras1223 6876 5
  • #1 16971275
    juras1223
    I have a problem and a question at the same time.
    Well, I moved about a month ago to a new apartment and immediately there was a problem with the ground because there was a cable but there was no antenna on the roof so I bought a cable and connected to the TV outlet that was in the apartment. Everything flickered, received all terrestrial television channels until suddenly in the morning I start the TV and "no signal" so already 2 days flies. What could be the reasons? I doubt that the maintenance work lasts two days so it's not that, the cable is new and from the more expensive ones, and it would go down immediately overnight? I also checked the socket with a test tube and there is no current flowing there, is it supposed to be? I think some current should flow and the tube should light up. I bet that the neighbor who is renovating above me cut the cable ... and this is the reason but maybe you have any ideas?
  • #2 16971350
    D214d3k
    The idea is to report it to the administration.
  • #3 16971905
  • #4 16973395
    juras1223
    oki thanks i will :)
  • #5 16974806
    KOCUREK1970
    Not necessarily - he could unscrew the sockets in the apartment at home and you are connected to them in series.
  • #6 17016576
    juras1223
    the gentlemen came and connected again :) as I wrote the broken circuit
