Analog TV Still Working After Move: Digital Channels Undetected, Except EskiTV
amadeusz999 20946 7
  • #1 16775857
    amadeusz999
    I moved to a new apartment, I plug the tv into the "tv" socket.
    Scans digital programs - finds nothing. It scans the analog - it found most of those that I wanted, except eskiTV. The same when connecting the cable to the SAT socket.
    I thought analog TV was already turned off. How it's working? Somebody knows.
  • #2 16775868
    spinacz
    Find out from the administration what cable network provides the signal and you'll know everything.
  • #3 16775869
    meaverick
    The first question is whether the network or this socket is provided by the operator or an external antenna, the second scan the digital and analog maybe there is an error.
  • #4 16775870
    Vytautas_YT
    Level 30  
    I understand that you have connected to the socket that is connected to the collective installation, you do not have your DVB-T antenna. Or so?
  • #5 16775929
    amadeusz999
    yes i don't have my antenna. I plugged into the socket, I don't know what it leads to.
    I scanned the number and analog. It still finds only analogies.
  • #6 16775968
    michalek1988
    Find out from the manager or neighbors if a digital camera is available, whether it requires an additional decoder.
  • #7 16776052
    Olek II
    Moderator
    They are probably programs of the social package left for residents with old TV sets, so that they have something to pay for the RTV subscription. :D
    As colleagues have written above, contact the administration.
  • #8 16778915
    irekr
    I will add that some cables transfer the DVB-T signal to DVB-C and place these programs in the hyperband (S channels). If the receiver is not equipped with a DVB-C tuner or there is no automatic switching, the receiver will not notice the signal.
✨ The user reports that after moving to a new apartment, their analog TV is still receiving channels, while digital channels remain undetected. They are connected to a socket whose source is unknown and do not possess a personal DVB-T antenna. Responses suggest checking with the building administration or neighbors regarding the cable network and whether a digital signal is available. It is noted that some cable systems may convert DVB-T signals to DVB-C, which could lead to compatibility issues if the receiver lacks a DVB-C tuner. Additionally, some analog channels may still be provided for residents with older TV sets as part of a social package.
