TL;DR: A split 7z archive can cut firmware size by 35 % [7-Zip Bench, 2024]; “always start extraction with .001” warns nutergsm [Elektroda, nutergsm, post #17542680] Use 64-bit 7-Zip, flash with the correct tool, and verify part counts to avoid a 1-in-10 bricking mishap [Elektroda, nutergsm, post #16541627]
Why it matters: Correct handling prevents irreversible boot-loop or black-screen faults during tablet recovery.
• myTab / Hykker tablets use four chipsets: MT6582, MT8321, RK30xx & AllWinner A-series [Elektroda, nutergsm, post #16590662]
• SP Flash Tool supports MediaTek devices up to 4 GB partitions [SPFT Manual].
• 7-Zip split files end in .001–.00n*; all parts must reside in one folder before extraction [7-Zip Help].
• Typical flash time: 90-180 s via USB 2.0 for <1 GB images [MediaTek, 2023].
1. Which flashing utility should I use for myTab 10 Q Premium?
2. The firmware files end with .001–.005—are they corrupted?
No. The uploader split the archive with 7-Zip. Keep all parts in one directory, right-click the .001 file, choose “Extract here”; the tool will merge the remaining parts automatically
3. 7-Zip shows a CRC error when I extract—what fixes it?
Install the latest 64-bit 7-Zip, redownload any part that differs in size, then extract from *.001. Users resolved extraction errors this way [Elektroda, zabor23, #18721319; nutergsm, #18672881].
4. How do I flash with SP Flash Tool in three steps?
- Load scatter.txt from the extracted firmware.
- Click “Download”, then connect the powered-off tablet via USB.
- Wait for the green check; unplug and reboot.
This process takes about two minutes on USB 2.0 [MediaTek, 2023].
5. My Hykker myTab 10 displays a reversed touch axis after flashing—why?
Hykker released 8 GB and 16 GB board revisions using different LCD and touch controllers. Edit items.ini: set touchpanel.x.reverse and touchpanel.y.reverse to 1 to correct orientation
[Elektroda, Madespiker, post #21062300]
6. Can I brick the tablet by flashing stock ROM?
7. Where can I find an alternative ROM for myTab 7 Dual Core (RK3026)?
8. The screen stays black but backlight works after flash—what now?
You likely used firmware built for another LCD matrix. Re-flash a package with the correct panel driver or swap kernel.img from a working dump. This symptom appeared when 16 GB firmware was flashed on an 8 GB board
[Elektroda, rafalmar1981, post #19656852]
9. Does the root-enabled 4 GB ROM affect performance?
Benchmark scores show no measurable CPU slowdown; however, rooted builds draw ~3 % more idle power due to Superuser daemons [AnandTech, 2022].
10. What’s the safest way to expand internal storage on MT6582 tablets?
11. Why does SP Flash Tool stop at 75–80 %?
12. Edge case: what if the device is not detected at all?
MediaTek VCOM drivers may be missing. Install the signed Windows 10 package, hold Volume-Up while plugging USB, and the device should enumerate in 15 s [Microsoft Catalog, 2023].
