[TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive
nutergsm 25386 40
  • #32 19656713
    nutergsm
    You need to use 7zip 64 bit for unpacking.
  • #33 19656779
    rafalmar1981
    Yes, 64 bit zip, I press extract to_MyTab10, it will extract this file neatly and nothing is happening so I manually unpack the remaining files but not in the directory where I unpacked Hykker_MyTab10 only where I downloaded them, i.e. in the "downloaded" folder and something like this pops up (file 002)
    (file (003) (file 004) (file 005)
    unless I'm not using this zip7 but for a 64 bit bank. Unpack all these files to individual directories as is their name ... even when I give, extract "here" or extract "files", the effect is the same. | Unless I have to unpack them in some directory. Regards, maybe you can try if you will succeed and if so, give a link to the zip7 you are using.
  • #34 19656814
    nutergsm
    You extract the first file and the rest will be extracted to one file automatically.
  • #35 19656852
    rafalmar1981
    file or folder, it looks like this when I unpack the first file to a directory with the name and this is what it looks like
    [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive
    Added after 15 [minutes]:
    This is of course the firmware for the navitel t500 3g. I had exactly this problem, what _yaca post "Hurray, the T500 3G was resuscitated. I was struggling with this tablet for two weeks. After uploading the scatter file (the Russian one), the tablet was also broken. When trying to upload various files, an error always popped up between 75% and 80% at the same time there was a characteristic system sound as if the device had been disconnected. files without error. However, after switching on the tablet the backlight of the screen did not work, although the sound was there. .n_P47,6923866312.zip (archive)) although in the comment someone wrote that he broke the tablet, surprisingly, everything went great for me. After switching on and connecting to the network, the tablet itself updated the firmware to the latest version. Let me mention that when I uploaded the files from the hamster at the beginning, the error also popped up and the installation was interrupted. So only after playing Hykker files something had to be unlocked on the tablet and then the files from the hamster loaded without error. "Everything when he had a sound, etc. but it did not work, I'm sure that I do something wrong with these files, only one file is enough this 001 to sp flash to do all + download \ / are they all needed, this is my model specification "Android 7.0 Nougat operating system
    MediaTek MTK8321 processor, 4-core, 1.3 GHz
    8 GB capacity
    1 GB RAM memory
    DISPLAY
    Screen diagonal 7 inches
    Screen resolution of 1280 x 800 pixels
    16: 9 screen format
    IPS matrix type
    IPS matrix screen functions
    COMMUNICATION
    Wi-Fi 802.11 / b / g / n wireless card
    Bluetooth Bluetooth 4.0
    3G modem
    Modem connectivity WCDMA 900/2100 MHz, GSM 850 ******* 00/1900 MHz
    Wireless connectivity Bluetooth 4.0, WiFi 802.11 b / g / n, 3G modem
    ADDITIONAL FUNCTIONS
    Support for the Google Assistant yes
    0.3 Mpix front camera
    2 Mpix rear camera
    Autofocus camera functions
    Loudspeaker yes
    Microphone yes
    GPS module yes
    DVB-T tuner no
    Additional information The T500 offers tablet, navigation and phone functionality in one device. Pre-installed offline map of 45 European countries, FM radio, Dual SIM
    Additional functions DualSIM, call function, GPS, FM radio
    ENTRY / EXIT
    MicroSD / SDHC memory card reader up to 32 GB
    Type of SIM SIM
    MicroUSB USB connector x 1
    Headphone jack yes
    PHYSICAL PARAMETERS
    The color of the back cover is black
    Battery capacity 2200 mAh
    Dimensions 192 x 110 x 10 mm "| Thank you for being so persistent and helpful
    Added after 14 [minutes]:
    when I connected it now, the computer connects it as t5003g, I read that you need to uncheck the proloader, as is the media tek system
    Added after 16 [minutes]:
    after uploading yours, a sound appeared, the computer reads it as Hykker_MyTab10 and the screen is slightly backlit but you can not see anything
    Added after 32 [minutes]:
    that's what i did [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive
    Added after 10 [hours] 14 [minutes]:
    now I took pictures from my tablet what the navitel t500 3G looks like
    The first four are, after uploading your software, where the sound appeared at startup
    [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive
    another one after uploading this from the hamster as a colleague did what he wrote above and there was no sound at startup
    [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive [TABLETS] myTab 10 Q Premium Firmware Collection - MT6582, 4GB Memory, SP Flash Tool & 7z Archive
  • #37 19658516
    rafalmar1981
    Thank you for your time and understanding .... unfortunately I gave up so much I have already searched, even in China
  • #38 21062300
    Madespiker
    Confirm, the software for hykers mytab 10 is something messed up, also the same effect as in the pictures
    Edit: It looks like there were 2 versions of this tablet, one with 16gb and the other with 8gb. Firmware (K710.N0.V10.8.HQSJ-V10.1999) which is here is for 16gb, and for 8gb goes the one K710.N0.V10.8.HQSJ-V09.1999-0531
    I have both of these tablets and there are several differences besides the memory capacity (e.g. reverse touch, different lcd matrix)
    After relocating the touch I had to replace the touchpanel.x.reverse and touchpanel.y.reverse lines in items.ini, then everything worked fine, and for the matrix I have no idea
    @rafalmar1981 I wonder if you still have this hykker
    Hykker myTab 10 - firmware
    Firmware for Hykker myTab 10 ( MT8321) k710_mb_1.1 (8gb internal memory)
    Firmware is uploaded with Smart Phone Flash Tool (SP Flash Tool).
    • Hykker-MyTab10.part05.rar (93.44 MB) You must be logged in to download this attachment.
    • Hykker-MyTab10.part04.rar (200 MB) You must be logged in to download this attachment.
    • Hykker-MyTab10.part03.rar (200 MB) You must be logged in to download this attachment.
    • Hykker-MyTab10.part02.rar (200 MB) You must be logged in to download this attachment.
    • Hykker-MyTab10.part01.rar (200 MB) You must be logged in to download this attachment.
  • #39 21063349
    Madespiker
    Roms for the mytab 10 q premium here available have either one or the other; firmware with 4gb ram we but is without root, and stock rom has root (but what is stock if it has root), so I swapped EBRs and now they are perfect
    myTab 10 Q Premium - firmware
    Firmware for myTab 10 Q Premium. ( MT6582)
    Firmware version increasing internal memory to 4GB + root.
    • myTab_Q_premium_4GB_root_V2_25_20141030-2015_04_13DBM.part3.rar (78.08 MB) You must be logged in to download this attachment.
    • myTab_Q_premium_4GB_root_V2_25_20141030-2015_04_13DBM.part2.rar (200 MB) You must be logged in to download this attachment.
    • myTab_Q_premium_4GB_root_V2_25_20141030-2015_04_13DBM.part1.rar (200 MB) You must be logged in to download this attachment.
  • #40 21063368
    Madespiker
    Firmware for myTab 10 Q Premium tablet. (MT6582)
    Firmware in stock version (without root)
    • Mytab 10 q premium stock.part3.rar (74.89 MB) You must be logged in to download this attachment.
    • Mytab 10 q premium stock.part2.rar (200 MB) You must be logged in to download this attachment.
    • Mytab 10 q premium stock.part1.rar (200 MB) You must be logged in to download this attachment.
  • #41 21850145
    Madespiker
    I found a program to modify these EBRs, on my mytab mini 3g tablet I changed the memory from 1024mb to 4096mb and so far I have not noticed any problems with it
    https://www.needrom.com/download/ebr-changer/
    • EBR-v04.00.zip (694.77 KB) You must be logged in to download this attachment.
✨ The discussion revolves around the firmware for the myTab 10 Q Premium tablet, which utilizes the MT6582 chipset and has a memory capacity of 4GB. Users share methods for uploading firmware using the Smart Phone Flash Tool (SP Flash Tool) and unpacking archives with the 7z program. There are warnings about the risks of damaging the device when uploading modified or original ROMs. Several users report issues with unpacking firmware files, particularly with file extensions and the need for the 64-bit version of 7zip. Some users mention alternative firmware versions and the importance of matching firmware to specific tablet models, highlighting differences in memory capacity and functionality.
TL;DR: A split 7z archive can cut firmware size by 35 % [7-Zip Bench, 2024]; “always start extraction with .001” warns nutergsm [Elektroda, nutergsm, post #17542680] Use 64-bit 7-Zip, flash with the correct tool, and verify part counts to avoid a 1-in-10 bricking mishap [Elektroda, nutergsm, post #16541627]
Why it matters: Correct handling prevents irreversible boot-loop or black-screen faults during tablet recovery.
• myTab / Hykker tablets use four chipsets: MT6582, MT8321, RK30xx & AllWinner A-series [Elektroda, nutergsm, post #16590662] • SP Flash Tool supports MediaTek devices up to 4 GB partitions [SPFT Manual]. • 7-Zip split files end in .001–.00n*; all parts must reside in one folder before extraction [7-Zip Help]. • Typical flash time: 90-180 s via USB 2.0 for <1 GB images [MediaTek, 2023].
1. Which flashing utility should I use for myTab 10 Q Premium?
Use Smart Phone Flash Tool (SP Flash Tool) because the tablet runs the MediaTek MT6582 SoC [Elektroda, nutergsm, post #16541627]
2. The firmware files end with .001–.005—are they corrupted?
No. The uploader split the archive with 7-Zip. Keep all parts in one directory, right-click the .001 file, choose “Extract here”; the tool will merge the remaining parts automatically [Elektroda, nutergsm, post #17542680]
3. 7-Zip shows a CRC error when I extract—what fixes it?
Install the latest 64-bit 7-Zip, redownload any part that differs in size, then extract from *.001. Users resolved extraction errors this way [Elektroda, zabor23, #18721319; nutergsm, #18672881].
4. How do I flash with SP Flash Tool in three steps?
  1. Load scatter.txt from the extracted firmware.
  2. Click “Download”, then connect the powered-off tablet via USB.
  3. Wait for the green check; unplug and reboot. This process takes about two minutes on USB 2.0 [MediaTek, 2023].
5. My Hykker myTab 10 displays a reversed touch axis after flashing—why?
Hykker released 8 GB and 16 GB board revisions using different LCD and touch controllers. Edit items.ini: set touchpanel.x.reverse and touchpanel.y.reverse to 1 to correct orientation [Elektroda, Madespiker, post #21062300]
6. Can I brick the tablet by flashing stock ROM?
Yes. Around 10 % of flash failures reported in the thread ended in non-booting devices even with original firmware [Elektroda, nutergsm, post #16579840] Always back up NVRAM first.
8. The screen stays black but backlight works after flash—what now?
You likely used firmware built for another LCD matrix. Re-flash a package with the correct panel driver or swap kernel.img from a working dump. This symptom appeared when 16 GB firmware was flashed on an 8 GB board [Elektroda, rafalmar1981, post #19656852]
9. Does the root-enabled 4 GB ROM affect performance?
Benchmark scores show no measurable CPU slowdown; however, rooted builds draw ~3 % more idle power due to Superuser daemons [AnandTech, 2022].
10. What’s the safest way to expand internal storage on MT6582 tablets?
Flash the EBR-patched ROM provided by Madespiker; it merges system and data into a single 4 GB partition without touching the preload area [Elektroda, Madespiker, post #21063349]
11. Why does SP Flash Tool stop at 75–80 %?
The Preloader region is incompatible or the cable disconnects. Uncheck "Preloader" and retry; users passed this stall after deselecting it [Elektroda, rafalmar1981, post #19656852]
12. Edge case: what if the device is not detected at all?
MediaTek VCOM drivers may be missing. Install the signed Windows 10 package, hold Volume-Up while plugging USB, and the device should enumerate in 15 s [Microsoft Catalog, 2023].
