HDMI cable question - connecting disconnecting the HDMI cable
9174 6
  • #1 16218682
  • #3 16219745
    kazikszach
    pexim wrote:
    nothing will happen
    Can you guarantee that nothing will happen?
  • #4 16229744
    1 PAWEL
    roko00 wrote:
    Can I disconnect or connect the HDMI cable to the TV or game console when the TV is on standby and the console is plugged in but not turned on (turned on)? Can something break?
    The HDMI cable should only be connected / disconnected on devices disconnected from the 230V mains.
  • #5 16229772
    sanfran
    And why HDMI cables have a "HOT PLUG detect" pin?
  • #6 16229815
    kazikszach
    Theory is good, but practice shows otherwise.
    I got some damaged TV sets at the plant, customers said the damage happened when connecting the HDMI cable with the equipment turned on.
The discussion revolves around the safety of connecting or disconnecting HDMI cables while devices are powered on or in standby mode. Responses indicate mixed opinions: some assert that nothing will happen, while others caution against it, citing potential damage to devices. One user references the "HOT PLUG detect" pin in HDMI cables, suggesting that they are designed for hot swapping. However, anecdotal evidence from another participant highlights instances of damage occurring when HDMI cables were connected with devices powered on, emphasizing the risks involved.
Summary generated by the language model.
