There is no signal on the TV connected via HDMI to the computer
makaveli026 4830 3
  • #1 16850882
    makaveli026
    Recently, I got a HDMI 1.4 10m cable from a friend and I wanted to connect a computer with a TV. The computer responds normally and divides the desktop into 2 screens, but the TV has no HDMI signal. I thought the cable was damaged, so I went to a friend, we checked it and it worked normally. He also lent me an HDMI cable (more expensive) 3m and (cheaper with a ladybug for PLN 20) 5m. On these cables my TV worked normally, but on this 10m I can not see the signal. I connected this cable to 3 HDMI connectors on the TV and nothing else. I have the drivers installed from the nvidi website. In my computer I have 2 Windows 7 and Kubuntu 16.04 systems and in each system detects the device, but the TV still has no signal.
    My graphics card: GeForce GTX 970 4GB Gaming
    TV: Samsung UE43J5500
    Colleagues graphics card GeForce 9600GT 1GB
    TV: Samsung UE32M5602
  • #2 16851546
    Polon_us
    The signal loss per 10m HDMI cable is too high in this case - computer-> TV connection.
    This cable may work with other devices (e.g. a friend) that generate a stronger signal.
    Not much can be advised here.
    Usually at such distances it is either:
    - much better quality cable
    or
    - HDMI repeater (repeater). Such an amplifier should have been connected halfway between devices.
    So in this case a good solution would be a 2 x 5m HDMI cable and a signal amplifier.
  • #3 16851565
    makaveli026
    From what I understood, is my graphics generating a weaker signal or the TV needs a stronger signal to display the image?
    Alternatively, can you make such an amplifier yourself or is it not profitable and better to buy?
  • #4 16851623
    Polon_us
    That's exactly what I meant by writing my entry.
    I can not answer.
    I'm afraid that making an HDMI amplifier at home can be difficult.
    Example of an amplifier -> link
