How to Detect Burnt or Malfunctioning 3-Phase Motors: Inspection Tips and Troubleshooting
vymiathatch 76030 14
  • #1 280819
    vymiathatch
    as above. I know that this type of engine burns in different ways, but how to detect if such an engine is actually burnt or not? Last year, in the work I was doing, the saliva burned down and I was called for a so-called inspection, is it really so? Basically, having a small idea about it, I assessed that it was burnt because it just had a transition between the housing and one of the phase terminals. but if it were not so? because I could only freeze a little inside and then I would have no idea how to check it, so please advise me :-) and maybe someone has a similar problem and will deal with it in some way? maybe he found something interesting about checking the correct operation of such an engine?
  • #2 280860
    POL02
    Home appliances specialist
    You can check the engine as follows.
    1. Breakdown test (whether the insulation between the winding and the motor housing is not damaged. This is done either with a breakdown tester at U = 1250V or IMI (inductor insulation tester)
    2. Measure the winding resistance (for a three-phase motor they should be equal to each other)
    3. Measurement of the idling currents in each phase (they should be equal).
    This is a basic check.
  • #3 281095
    gmp
    Level 19  
    You can still disconnect the windings and check for breakdowns between them. Sometimes the cause of the damage is sometimes the bearings or bearing seats, the motor then "jerks" - and then the stator rubs the winding.
  • #4 281136
    stasiekm
    Level 30  
    It is also very useful to measure the inductance of the windings - the same principles as when measuring resistance
  • #5 281616
    vymiathatch
    I know the first two methods described by my colleague POLO2, but I do not know what it is about, i.e. I interpret it like this, you should turn on the motor itself without any load on the shaft and then measure the currents coming to the motor, if they are equal, the motor is operational and if they are different then where there is more current the winding is burned out
  • #6 281673
    Spiderek
    It is best to measure the resistance of individual windings, they should be equal to each other, although the value is relatively small, then it will turn out if it makes sense at all to do something with it
  • #7 281711
    Czesiek
    It happens that everything looks fine from the measurements and the squirrel cage motor has no "power". The cause may be a crack or a burnout in the aluminum rotor winding. Often invisible to the eye.
    What is best for a different rotor to be checked. Determining such damage is sometimes only possible with an industrial X-ray, and it is profitable with larger motors.
  • #8 281715
  • #9 281931
    vymiathatch
    and what row are the resistances of these windings? kilo ohms or maybe ohms? and if I do not have the windings drawn on the box, I will put the meter to the end of two neighbors. then my measurement was for nothing. what do you say?
  • #10 281984
  • #11 284891
    tprzemko
    Most three-phase motors burn when they run on two phases. You can add some security.
    To check the motor is not damaged, it is best to immediately treat it with an inductor if it has the appropriate resistance to ground. Usually, when the insulation drops, the winding will have a breakdown on the motor body and a specific smell. After positive insulation measurement, check whether the transition is between the windings, and finally measure the currents with clamps. It very often happens that the engine in the machine cannot start and most often it is a mechanical fault, something that is obliterated. Just check that the motor shaft can be turned by hand
  • #12 285623
    belka3
    You can also check the current during operation at individual phases, sometimes only a few windings will stick in the middle of the motor will work,
    electronic omomież will show a slight difference like everything is ok.
    But while you work, you may notice significant current differences.
  • #13 285641
    ACULA
    can be checked on one phase: connect in a delta, then connect the wires 220 to the third to the two terminals and, for example, to the second one connect a capacitor. Of course, the real strength of the engine cannot be checked in this way.
    This way you can check if it works at all, broken bearings, bent axle etc. You can also more or less check the power by trying to stop the axis rotation.
  • #14 324885
    piotrpak
    Once upon a time I had a case that the entire rotor package was displaced ....
    The current at idle speed was only half lower than the rated current
  • #15 325108
    macher
    If you have a drop in power, it may be due to the gearing of the motor and short-circuit between turns on some phase. The motor will consume more than the nominal current and it will be weaker. You will detect this with an ohmmeter.
    If you have 3 terminals, you measure each with each other, you have 3 measurements and these are the resistances of the windings in the 3 phases of the stator should be the same.
    If you have 6 clamps, it's like a gulson.
    8O
    trickster
To detect burnt or malfunctioning 3-phase motors, several inspection methods are recommended. Key techniques include performing a breakdown test to check insulation integrity, measuring winding resistance to ensure equal values across phases, and assessing idling currents for discrepancies. Disconnecting windings to check for breakdowns and measuring inductance can also provide insights into motor health. Additionally, checking for mechanical issues, such as bearing problems, and observing for unusual smells can indicate damage. For more complex issues, such as rotor winding failures, advanced methods like industrial X-ray inspection may be necessary. Proper labeling of windings and understanding their configurations (star vs. delta) is crucial for accurate testing.
Summary generated by the language model.
