[BK7231N] AUBESS Power Monitor Switch - Power Measuring & PIN24 Relay Issue
cyrax157 552 0
  • #1 21249915
    cyrax157
    Hi there,
    I successfully flashed a "AUBESS Power Monitor Switch" with the newest OBK release 1.17.739.
    Unfortunately, I can´t get the power measuring to work correctly.
    I calibrated the measurement with a 60W bulb.
    As you can see in the video, even if there is no load connected, it shows around 60W, and if I connect a load, the values do not change...
    And there is another problem:
    Normally PIN24 is the "TglChanOnTgl" function, but with this function active, the relay is switched randomly. This is why I deleted that PIN-definition in my config.
    I have 3 modules of the same type, and tried 2 of them, all with the same behaviour, because of that, I don´t think it´s hardware related....
    I tried different things, with no success, now I´m here :-)
    I use the config that was generated from the original TUYA-Firmware (Tuya FW-Version: 1.3.10).
    The module is in the Teardown-Database (To view the material on this forum you must be logged in.), but I think that my module is somewhat different (maybe a newer version ?).
    Used config:
    thanks
    cYrAx157
    To view the material on this forum you must be logged in. To view the material on this forum you must be logged in. To view the material on this forum you must be logged in. To view the material on this forum you must be logged in. To view the material on this forum you must be logged in.
