Step-by-Step Guide to Upgrade Firmware on Podofo Car Media Player Head Unit V9.OBT-TP
richienelson1719 32058 1
  • #1 20843846
    richienelson1719
    @ElektrodaBot Give me a tep by step instructions fore upgrading the firmware on my podofo car media player head unit soft version:V9.OBT-TP
    Info: MP5QHD70W1011F01M
    MCU6925:129.42
    CMLPLAY ver:CMLPLAY 9.0
    date:2022.09.07 19:22:57 this is a touchscreen car stereo
    @ElektrodaBot
    @ElektrodaBot Give me a step by step instructions for upgrading the firmware on my podofo car media player head unit soft version: V9.OBT-TP
    MCU6925: 129.42
    CMLPLAY ver: CMLPLAY 9.0
    date: 2022.09.07 19:22:57 this is a touchscreen car stereo @ElektrodaBot
  • #2 20843848
    ElektrodaBot
    AI OpenAI ChatGPT4
    MCU6925:129.42
    Upgrading the firmware on a car media player can be a bit tricky if you're not familiar with the process, as it varies between manufacturers and models. However, I can provide you with a general guide on how to attempt this. Before proceeding, please ensure that this is absolutely necessary, as a failed firmware update can sometimes render your device unusable (a condition known as "bricking").
    Here's a step-by-step guide that you can use as a reference:
    1. Check for Updates: First, visit the Podofo official website or contact their customer support to check if there is a firmware update available for your specific model.
    2. Download the Firmware: If there is an update available, download the correct firmware file for your model. Make sure you're getting the file from the official source to avoid potential issues.
    3. Read Instructions: Often, the firmware download will include or link to a set of specific instructions for updating your model. Read these carefully before proceeding.
    4. Prepare a USB Drive: Format a USB drive to FAT32, which is usually the required format for these updates. Make sure there are no other files on the USB drive.
    5. Copy Firmware to USB Drive: Copy the downloaded firmware file to the root directory of the USB drive. Do not place it inside any folders, unless otherwise specified in the instructions.
    6. Car Battery Check: Ensure that your car's battery is fully charged, or keep the engine running during the update process to prevent the unit from shutting off during the firmware update.
    7. Insert USB Drive: With the car turned off, insert the USB drive into the USB port of your car media player.
    8. Enter Update Mode: Start your car and then turn on the media player. Access the settings menu to find the firmware update option. This could be located in 'System Settings', 'About Device', or a similar location within the menu.
    9. Begin Update: Follow the on-screen prompts to start the update process. This may involve selecting the firmware file on the USB drive or simply confirming that you want to proceed with the update.
    10. Do Not Interrupt: Once the update process starts, do not turn off the car or the head unit, and do not remove the USB drive. Interrupting the update can cause the unit to malfunction.
    11. Completion: After the update is complete, the unit may reboot automatically. If not, you should manually reboot the device.
    12. Verify Update: Once the unit is back on, go to the settings where the firmware version is displayed and verify that it shows the new version.
    If you encounter any issues during this process or if something doesn't seem right, it's best to stop and seek professional assistance. Can you access the official Podofo website or have you been in touch with their customer support for the correct firmware file?
