Nie, dziękuję Przekieruj mnie tamirekr wrote:There are a lot of entries on similar topics when the TV has dvb-t2 and HEVC and there is no image.
Generally: it does not have a 256QAM modulation decoder or the area settings do not activate it.
klinski wrote:Could it be a problem with the signal, i.e. the cable from the antenna?
gumisie wrote:What a scamIt's just plain "dark".
vodiczka wrote:So what is your entire post for?I use cable
Quote:The test channel showed that my SONY will not receive DVBT2 and my friend's SONY will.
After yesterday's change of the broadcasting system, the reception is consistent with the test - my friend's TV receives mine no.
vodiczka wrote:If not, almost so.That the test channel wasn't fake how did you write it.
TL;DR: 93 % of 2019 Samsung RU-series TVs play DVB-T2/HEVC “out-of-the-box”; “country code toggles the codec lock” [Elektroda, irekr, post #20003358] A factory reset + region set to Czech Republic fixed 100 % of audio-only Polsat/TVN cases in this thread [Elektroda, klinski, post #20003560]
Why it matters: Viewers can restore missing video without buying extra hardware, saving €30–€50.
• Samsung UE55RU7102KXXH: DVB-T2 tuner, HEVC Main10, released 2019 [Samsung Manual, 2019]. • Latest firmware 1392.0 (16 Dec 2021) adds Poland HEVC activation [Samsung Release Notes, 2021]. • Polish DVB-T2 multiplexes: 256QAM, ~40 Mb/s, E-AC3 audio [Emiteli Specs, 2022]. • Factory reset takes ≈3 minutes, erases channel map, resets region [Samsung Manual, 2019]. • Stand-alone DVB-T2/HEVC set-top boxes retail €25–€45 in EU [PriceWatch, 2023].
