[Solved] remote control from the NC + decoder - The remote control does not work when hel
Skipperab kobieta 24423 9
  • #1 17535454
    Skipperab kobieta
    Hello, we have a 3-year-old son who puts everything in his mouth. For some time now he loves to put all the remote controls in his mouth, even though we forbid him to do so. Unfortunately, yesterday he was so biting the NC + remote and it stopped working. We thought maybe we were aiming the remote control wrongly at the decoder, are there any furniture / toys on the way from the remote to the decoder. However, whenever we pressed the TV button on the remote control (which, by the way, was to enable control of not only the decoder but also the TV, but on any of the TVs it never worked, so the button treated as such to check the remote control more), the red LED next to it was lit . Now, however, nothing is happening. We have a multimeter, we have screwdrivers, we have a soldering iron, and we would start repairs yesterday, but we want to start by asking you on the electrode. We suspect that maybe the batteries suddenly died, but that they would discharge to zero in an instant ??? Where to start the repair - do you have any ideas?
  • #2 17535517
    kokapetyl
    Nothing is easier than replacing them with new ones. :D
    If this does not help, then you need to disassemble the remote control, check if it is not wet / damp (possibly cleaned)
    Wait with the soldering iron. :cry:
    beta5
    Hello. I was dismantling the same remote control a moment ago, remove the batteries and measure with a multimeter, it should be at least 3.15 V. The batteries are connected in parallel so the LED from the TV button lights up even on one battery. Dismantling is done by pressing into the groove between the black and white halves and gently pulling both halves and so around the entire circumference of the pilot. After disassembly, everything can be wiped or washed with alcohol (except for the transparent insert with a conductive layer). You also need to look at solder connections and tracks, preferably through a magnifying glass. After drying and assembling (pay attention to the transparent insert because you can put it on the other way round) it should work. best regards
  • #4 17535749
    Skipperab kobieta
    beta5 wrote:
    Hello, I was dismantling the same remote control a moment ago, remove the batteries and measure with a multimeter should be at least 3.15 V. the batteries are connected in parallel so the LED from the TV button lights up even on one battery, Disassembly consists in pressing the groove between the black and white halves and gently pulling both halves and so around the entire circumference of the remote control, after disassembling everything can be rubbed or washed with alcohol / after a transparent insert with a conductive layer applied / you also need to see soldered connections and tracks and preferably through a magnifying glass, after drying and assembling / note the transparent insert because you can assume the other way around / it should work. Regards
    Okay, I'll do as you say and let me know.
  • #5 17535783
    Grzegorz_madera
    First you write:
    beta5 wrote:
    it should be at least 3.15V
    and later:
    So how can I get 3.15V from two 1.5V batteries in parallel?
  • #6 17536123
    Covul
    In such a remote control there are cr 2032 batteries, 3V each. Once you put it on your feet, you can set the remote control to control the TV, I found the manual on the Internet once, I did not search for long, Google will definitely help.
  • #7 17536585
  • #8 17536715
    makaber
    mihal2002 wrote:
    And do you know what batteries are there? Think before writing.
    It is not even known what the pilot is! The modest description with a red LED is also compatible with the Pace PVR remote (the one after the number +, but nc also offered it in the prepaid offer).
    @Skipperab woman , give the decoder model or give a photo of the remote control because in a moment you will be sent for some strange batteries for a completely different model ;)
  • #9 17536769
    LeDy
    He can first see if any button on the remote control is blocked.
    Why is this writing about batteries if you don't know what decoder, remote control?
  • #10 17585454
    Skipperab kobieta
    I close the topic. [/ U]
✨ The discussion revolves around a malfunctioning NC + remote control, which stopped working after being bitten by a child. Users suggest checking the batteries, which may have died suddenly, and recommend disassembling the remote to inspect for moisture and solder connections. The remote control uses CR2032 batteries, and users advise measuring the battery voltage with a multimeter. They also emphasize the importance of ensuring that no buttons are stuck and that the remote is aimed correctly at the decoder. The conversation highlights the need for specific model information to provide accurate troubleshooting advice.
