[Solved] Amica ZZA6428 Dishwasher Basket Rust Issue: Solutions, Renovator Ral 9016, Substitutes & Costs
gaijina 19041 11
  • #1 17426787
    gaijina
    Hey.
    I have a 10-year Amica ZZA6428 dishwasher. They have been starting to corrode my bins for some time. The enamel on the tips falls off and the bars begin to rust. Buying substitutes costs about PLN 400. I found something like this :arrow: link .
    Household appliances Renovator Ral 9016 White
    Quick-drying acrylic lacquer for painting and renovation: refrigerators, washing machines and other home appliances. Does not yellow, conducts heat well, dries quickly. Ideal for renovating the outer layers of metal household appliances. Provides a durable, smooth, washable surface.
    Withstands high temperatures up to 100 ° C
    For use directly on household appliances. Resistant to moisture and rust. Creates smooth, even coatings with a glossy finish.
    Colors: the most popular color RAL 9016
    Short drying time up to 5 minutes!
    Non-stick: 15-20 min; Total hardening: 16-20 h
    Coverage: 1.5-2 m ? depending on the substrate, with one application
    Hard acrylic coating extremely resistant to abrasion and water
    For outdoor and indoor use
    400 ml capacity
    Only will it remain on the uneven surface and can it be used in the dishwasher? Any of you know any way to stop the process even temporarily?
    Thanks.
  • #2 17426952
    lamer89
    Rather, this paint is intended to enhance the aesthetics of the washing machine / free standing dishwasher housing which housing has started to corrode.
    Under the conditions in the dishwasher, rather no one-component paint can withstand (temperatures, water, chemistry).
    You can try a two-component epoxy primer, or ask at your nearest powder coating shop how much they will take to repaint these baskets.
  • #3 17427274
    teskot
    Rest in Peace
    I would damage damaged areas (after cleaning) with two-component glue. Distal comes to my mind immediately. Of course, if the damage is small; otherwise it will be an ant work.
  • #4 17427440
    Borutka
    Distal can't stand it, I tested it in a dryer and it still made a mess. I wouldn't apply any home-grown patents. Too much risk of interior contamination and damage. You'd better leave it as it is.
  • #5 17427639
    mrice
    Moderator of Home appliances
    That's usually the effect of stuffing in baskets for strength and bending rods.
    Look for used bins in good condition.
  • #6 17427702
    teskot
    Rest in Peace
    Hmm, it seemed to me that Distal could easily handle it at, say, 80 ° C. Or maybe if the ends of the rods themselves rust, put on them heat shrink sleeves and seal at the ends?
  • #7 17428846
    gaijina
    The rust is on the tips not touched so imputation of plates damage falls.
    Nice idea with t-shirts just how to seal the ends? Drip with plastic?
  • #8 17428960
    teskot
    Rest in Peace
    T-shirt at the shrinking stage (lighter, burner, etc.) becomes soft. If the tip is heated strongly, it will melt and will be able to be sealed after pressing with pliers.
  • #9 17428989
    gaijina
    I will test thanks. I'll let you know how it turned out.
  • #10 17436847
    lamer89
    Now think what the effect will be when using the dishwasher during the drying phase. The dishes stuck to the heat-shrink tubing and the stench of plastic from them is rather not pleasant.
  • #11 17436932
    teskot
    Rest in Peace
    I have not yet met heat shrink sleeves that would soften at a temperature of several dozen ° C. Anyway, there are no contraindications for washing most plastic dishes in the dishwasher. Even in boiling water, T-shirts don't really want to shrink. The heat gun in first gear (apparently just over 200 ° C) also does not work well with them.
  • #12 17447990
    gaijina
    I put 4.8 / 2.4 white heat shrink tubing on rusting tips. I squeezed the pliers at the end. Some of the heavily warped ends had to be properly scraped off the rust for the shirt to enter. I think it worked out quite well.
    I'm worried about a few outbreaks that I can't protect in this way, but I'm happy now. I will monitor the security status, although I feel that it will last long.
    Thank you for the advice.
✨ The discussion revolves around the rusting issue of the Amica ZZA6428 dishwasher's basket after 10 years of use. Users suggest various solutions to mitigate the corrosion, including using two-component epoxy primers or powder coating for repainting the baskets. Some recommend applying two-component glue for minor damages, while others caution against using home remedies due to potential contamination risks. A user shares a successful method of using heat shrink tubing to cover rusted tips, which involved scraping off rust and sealing the ends with pliers. Concerns are raised about the durability of the heat shrink tubing under dishwasher conditions, particularly during the drying phase. Overall, the community provides practical advice and alternative solutions to address the rusting problem.
TL;DR: Rusty Amica ZZA6428 racks? Replacements cost ~PLN 400; "Withstands high temperatures up to 100 °C." This FAQ explains safe fixes for basket rust and tip patches for owners of this model. [Elektroda, gaijina, post #17426787]
Why it matters: You’ll stop rust transfer to dishes and delay costly rack replacements.
What’s the quickest way to stop dishwasher rack rust on an Amica ZZA6428?
For localized tip rust, clean the spots and sleeve them with heat‑shrink tubing. A user reported success using white 4.8/2.4 mm sleeves, then crimped the softened ends with pliers. Clean heavy rust so the sleeve slides on. This is a fast, reversible patch that prevents further chipping and protects dishes from rust. Monitor periodically for wear or new rust points. “I think it worked out quite well.” [Elektroda, gaijina, post #17447990]
Can I use RAL 9016 appliance spray inside the dishwasher?
No. It’s meant for appliance exteriors. “Under the conditions in the dishwasher, rather no one‑component paint can withstand.” Heat, water, and detergents degrade single‑component acrylics fast. If you want a coating, use a two‑component epoxy primer, or ask a powder‑coating shop about recoating racks. These survive the wet, hot, alkaline environment much better than aerosol touch‑ups. [Elektroda, lamer89, post #17426952]
Will heat‑shrink sleeves soften or smell during drying?
There’s a cautionary report. One contributor warned that sleeves can soften during drying, stick to dishes, and smell of plastic. “The dishes stuck to the heat‑shrink tubing and the stench of plastic... is rather not pleasant.” If you try sleeves, keep them short on tips, and verify they’re stable in your machine’s hottest cycle before full use. [Elektroda, lamer89, post #17436847]
How do I seal the ends of heat‑shrink tubing on rack tips?
Heat the sleeve until it softens during shrinking. Then pinch the end with pliers to close and seal it. This prevents water ingress and reduces snagging. A lighter or heat gun provides controlled heat; avoid scorching plastic parts nearby. The key is to press while the sleeve is soft so it bonds shut. [Elektroda, teskot, post #17428960]
What size heat‑shrink fits the rack tips on this model?
A successful user fix used 4.8/2.4 mm heat‑shrink sleeves on the rusting tips. They cleaned heavy rust to allow the sleeve to slide on, shrank it, and crimped the end with pliers. Color choice is cosmetic; white blends with the rack. Inspect for other spots you can’t sleeve and monitor them. [Elektroda, gaijina, post #17447990]
Is two‑component epoxy or powder coating worth it for racks?
Yes. Two‑component epoxy primers and professional powder coating handle heat, water, and detergents far better than one‑component sprays. Ask a local powder‑coating shop about blasting and recoating baskets, or use a 2K epoxy system if recoating yourself. These options deliver harder, more chemical‑resistant films. [Elektroda, lamer89, post #17426952]
What causes rack rust on Amica ZZA6428 baskets?
Overloading and bending rods stresses and cracks the enamel. Once steel is exposed, corrosion starts at tips and spreads. Avoid stuffing heavy items that pry against tines. Check for bent rods and correct them gently to reduce new enamel breaks. [Elektroda, mrice, post #17427639]
Is two‑part glue like Distal a good repair for tips?
No. A user tested Distal and it failed under heat, leaving a mess. “Distal can’t stand it... made a mess.” Adhesives risk flaking into the tub and contaminating dishes. Avoid glues inside the dishwasher cavity. Choose sleeves or professional recoating instead. [Elektroda, Borutka, post #17427440]
How much do replacement or substitute racks cost?
Approx. PLN 400 for substitute baskets, per user report. Prices vary by availability and condition, but budgeting around that figure helps decide between patching and replacing. Check local listings and parts vendors for current offers. [Elektroda, gaijina, post #17426787]
Should I consider buying used dishwasher racks?
Yes. Look for used bins in good condition if your rack is too far gone. Inspect enamel integrity and straightness of tines before buying. This can be more economical than new substitutes if the enamel remains intact. [Elektroda, mrice, post #17427639]
How do I apply heat‑shrink tubing to rusty rack tips (3 steps)?
  1. Clean the tip. Scrape loose rust so the sleeve slides on.
  2. Fit the sleeve. Position it over the damaged area.
  3. Shrink and seal. Heat to shrink, then crimp the softened end with pliers to close it. [Elektroda, gaijina, post #17447990]
Does uneven, pitted enamel affect paint adhesion on racks?
Yes. Inside-dishwasher conditions—heat, water, detergents—quickly undermine one‑component acrylics, especially on uneven, pitted enamel. If you must repaint, switch to a two‑component epoxy primer or pursue powder coating. These options cope better with the rack’s shape and environment. [Elektroda, lamer89, post #17426952]
What coverage will a 400 ml RAL 9016 can deliver?
Approx. 1.5–2 m² per application, depending on the substrate. Typical handling times: non‑stick in 15–20 minutes and full cure in 16–20 hours. Note: These specs refer to appliance exterior use, not dishwasher interiors. [Elektroda, gaijina, post #17426787]
