No Hotbird 13E Signal in Norway: Digital Polsat Antenna Setup Issues, Schweiger Meter & Astra
83pawel 15258 15
  • #1 17391728
    83pawel
    Hello, I am trying to set up an antenna for a digital polsat in Norway and I have a big problem.
    I installed the antenna in my new home after moving and the signal just went blank. The antenna is the same that previously worked and on which I received digital polsat for several years, the converter too (but to be sure I replaced the cable and converter with a new one).
    I tried to set it myself because I cannot call a specialist: I set the elevation angle as it should be for my town (I also tried to set it higher and lower to no avail). I tried to catch the direction with a cheap meter, which showed something, but I did not know what satellite I was tracking and the decoder showed 0% all the time. Later I bought a better Schweiger meter, which shows what satellite I am tracking and it turned out that it got a good signal on the astra 5E and astra 19.2E and between nothing, literally minimal signal flashes. I made minimal movements when setting up, I literally moved the converter by 1mm and then tried again the same on the connected decoder and still nothing 0%. The trees do not cover (the astra would be more) the trees are about 3-4 m above the antenna at a distance of 15-20m so it's not really that. The neighbors have their antennas set to 0.8 thor and they take it away somehow and I don't even get it. Anyone have ideas what's going on? What am I doing wrong?
  • #2 17391736
    andpol 33
    Here: link you have HB coverage maps. Maybe a larger antenna is needed in your location?
  • #3 17391806
    83pawel
    I have an even larger antenna, the local one (I think it has 70 cm) and it can pick up on other small Polish antennas. And the set-up movements were minimal and I didn't catch the hotbird. Both the 5E and 19.2E asters have a good signal
  • #4 17391852
    _kli_
    83pawel wrote:
    I installed the antenna in a new home after moving
    83pawel wrote:
    The antenna is the same that worked before and on which I received digital polysat for several years
    Moving carries the risk of damaging the antenna. A small deformation of the canopy is enough and you may have problems with the correct alignment of the antenna system.
  • #5 17391915
    83pawel
    Is there a chance it's because of the canopy? I could buy a new one tomorrow if it's in the store. So why do these asters perceive so well, and in a large range of motion? They have such a good signal?
  • #6 17391933
    andpol 33
    Since there is HB range in those areas on the 70 and you don't have any obstacles in front of the antenna, you simply can't set it up.
  • #7 17391945
    PewexM
    I think the trees are blocking your signal.
    From 5E to 19.2E is a big gap and you write that the trees are 3-4 meters above the antenna
    and 15-20m away from it and it is still close.
  • #8 17392089
    _kli_
    It depends what region of Norway it is. In the south, the height of the obstacle should not exceed approx. 40% of its distance, and in the north - approx. 20% of the distance.
  • #9 17392169
    83pawel
    For me, the angle should be around 19 degrees. So after 15 m it is already over 5 m higher. And these trees are even more than 15m, from what I checked. I could cut them out, but I feel sorry for them because that is probably not the reason. And I wrote earlier that these trees cover the astra more. In the direction of 13E, they should cover even less and the astra has a strong signal.
    Added after 15 [minutes]:
    It is highly probable that I cannot set it up, so please give me a hint here.
    I would like to take a specialist for this, but I do not have such a possibility. If there is a fitter from Nord-Sterdal in Norway, I will gladly order the connection.
  • #10 17392234
    LeDy
    PewexM wrote:
    you write that trees are 3-4 meters above the antenna
    and 15-20m away from it a it is, however, close .
    You write nonsense.
    To the author.
    Also change the angle of inclination. Do you have the canopy holder vertically or "by eye"?
  • #11 17392250
    83pawel
    I changed the slope angles gradually +1, + 2 and -1, -2 and made slow passes through the whole range, but then the signal from other satellites was even worse. 100% vertical handle. Now I think that maybe I actually have to buy a new antenna, but it will take time before I order a larger, unusual size and it will probably cost a bit.
  • #12 17392260
    LeDy
    And you can't + - more than 2 °? When it receives another satellite, the antenna cannot be distorted.
    What you bought to set up slowly, wait, move around.
  • #13 17392264
    83pawel
    When I was taking more than 2-3st. then he could hardly catch anything, so it seemed to me that maybe it didn't make sense.
  • #14 17393088
  • #15 17395344
    iwanak
    I had the same thing after moving in Poland, how I set it on a belt
    signal level on the TV. I think the large inertia of indications.
    I bought a signal meter for a pair of zeta and the problem was gone.
  • #16 17395382
    irekr
    It is a pity that you do not specify which region of Norway it is. It is different in Oslo, different in Bergen and different in Narvik.
    From my own experiences in the north of Lekanger:
    1. HB has weaker signal than Astra by at least 8 dB
    2. It can be set on the antenna from Thor (70) but the signal is on the borderline of reception, a bit of clouds is enough and after the signal. I was betting 140 cm Andrew. Works to this day.
    3. One of the key principles of carrying weak signals - do not use simple indicators, because with such weak signals it is difficult and sometimes too difficult for an inexperienced person.
    4. With such weak signals, I would practice searching with the old DVB-S decoder, not S2 (the "click" time is about half a second, not more than 4 seconds). We set the antenna not to CP / NC + signals, but to some "old DVB-S".
    Most often I start from 11179 H, where TVP Polonia is broadcast, but from the transmitter near Venice (or Milan) and in DVB-S MPEG2, the signal is strong and stable. If you set the force to the maximum and minimum error, I repeat everything on 11526 H (Swiss SRG SSR but already on DVB-S2) and only then check 10719 V or 10727 H, where there are several Polish non-coded stations. If it works correctly, then I connect the CP or NC + decoder.
    If you have an open space between 19E and 5E, it would not work ...
    Success ...
    And I have fond memories of herring in chocolate .....
    It may come in handy:
    https://www.lyngsat.com/Eutelsat-Hot-Bird-13B-13C-13E.html
✨ The discussion revolves around issues faced while setting up a Digital Polsat antenna in Norway, specifically regarding the lack of signal from Hotbird 13E despite successful reception in the past. The user has replaced the cable and converter but still experiences signal loss. They have tried adjusting the elevation angle and using both a cheap meter and a Schweiger meter, which indicates good signals from Astra 5E and Astra 19.2E but not from Hotbird. Responses suggest that potential obstacles, such as trees, may be blocking the signal, and that a larger antenna might be necessary for reliable reception in Norway. The importance of proper alignment and the potential need for professional assistance are also highlighted.
TL;DR: Hot Bird 13E can be ≥8 dB weaker than Astra in northern Norway; "HB has weaker signal than Astra by at least 8 dB." Use a larger dish, clear obstacles, and align on DVB‑S 11179 H then 11526 H. [Elektroda, irekr, post #17395382]
Why it matters: This FAQ helps Cyfrowy Polsat viewers in Norway fix “no Hotbird signal” by choosing the right dish, clearing obstructions, and aligning correctly.
Why can I get Astra 5E/19.2E but not Hot Bird 13E in Norway?
Hot Bird in Norway can be ≥8 dB weaker than Astra. That smaller margin exposes alignment errors and minor obstructions. A 70 cm dish may work on Astra yet fail on 13E. Use a larger dish in the north and align precisely. Peak on DVB‑S 11179 H, then confirm on 11526 H before scanning. “Do not use simple indicators with such weak signals.” [Elektroda, irekr, post #17395382]
What size dish do I need for Hot Bird 13E across Norway?
In northern areas, a 140 cm Andrew dish gave stable Hot Bird reception. A 70 cm dish from Thor works but is borderline. Cloud cover can drop a borderline signal to zero. In the south, smaller dishes may work when alignment and clearance are ideal. Choose headroom if you want weather resilience. [Elektroda, irekr, post #17395382]
Do trees 15–20 m away block 13E, and how much clearance do I need?
Apply the clearance rule. In southern Norway, obstacle height should be ≤ 40% of its distance. In the north, use ≤ 20%. At 20 m distance, that means ≤ 8 m south or ≤ 4 m north. Trees 3–4 m above the dish at 15–20 m can block 13E in the north. [Elektroda, kli, post #17392089]
Could moving the dish bend it enough to lose only Hot Bird?
Yes. Moving can deform the reflector slightly, which spoils focus and gain. Small deformations make precise alignment harder. With weaker 13E margins, you may lose lock while Astra still appears. Inspect the dish profile and mount for subtle bends or twists. Replace if warped. [Elektroda, kli, post #17391852]
How do I align to Hot Bird 13E without a pro meter?
Use a fast-lock method and known transponders. 1. Connect an old DVB‑S receiver for fast lock (~0.5 s vs up to ~4 s). Tune 11179 H. 2. Sweep slowly. Maximize signal and minimize errors. Confirm on 11526 H, then 10719 V/10727 H. 3. Tighten bolts, then connect your CP/NC+ decoder. “We set the antenna not to CP/NC+ signals, but to some ‘old DVB‑S’.” [Elektroda, irekr, post #17395382]
Which Hot Bird transponders are best for initial lock and peaking?
Start on 11179 H (TVP Polonia, DVB‑S, MPEG‑2) because it is stable. Verify alignment on 11526 H (SRG SSR, DVB‑S2). Finally, check 10719 V or 10727 H for Polish FTA channels. These carriers confirm azimuth, elevation, and skew. Only after peaking should you connect your Polsat decoder. [Elektroda, irekr, post #17395382]
My TV’s signal bar lags; is that why I miss 13E?
Yes. The on‑screen signal meter can have large inertia and mislead aiming. One user fixed the issue by using a small external signal meter. The dedicated meter refreshed faster and simplified peaking. Consider an inline tool during final adjustments. [Elektroda, iwanak, post #17395344]
Are simple sat finders enough for weak Hot Bird signals?
For weak 13E signals, avoid basic buzzers. “Do not use simple indicators, because with such weak signals it is difficult.” Use a receiver that locks quickly and shows BER. Older DVB‑S boxes respond in about 0.5 seconds versus up to 4 seconds. That responsiveness makes fine adjustments practical. [Elektroda, irekr, post #17395382]
Does mast verticality really matter for 13E aiming?
Yes. Ensure the dish’s pole is exactly vertical, not “by eye.” A tilted mast skews elevation and complicates peaking. After leveling, vary the inclination deliberately and re‑scan. Small errors stack when chasing a weaker satellite like 13E. [Elektroda, LeDy, post #17392234]
Should I widen my search beyond ±2°?
Yes. Expand elevation and azimuth sweeps beyond ±2° when you do not see a lock. Move slowly and pause for readings to stabilize. Keep trying even if other satellites weaken during the sweep. The key is a patient, deliberate search. [Elektroda, LeDy, post #17392260]
Where can I check Hot Bird coverage for Norway?
Use the Hot Bird coverage maps referenced in the thread. Check your location’s footprint and choose an appropriate dish size. If you are near the edge, select a larger reflector for margin. [Elektroda, andpol 33, post #17391736]
Do I need to cut trees, or will trimming help?
Trim rather than cut. As one installer noted, you do not need to remove trees, only shorten them. Also note that 70 cm dishes may be insufficient in Norway. Combine trimming with the right dish size for reliable service. [Elektroda, Anonymous, post #17393088]
What elevation should I expect around central Norway?
The OP’s location required about 19° elevation for 13E. Expect similar values in central Norway, with small local variations. Use this as a starting point, then refine during peaking. [Elektroda, 83pawel, post #17392169]
If I can get Thor 0.8°W on 70 cm, will 13E also work?
Not guaranteed. In the north, 70 cm on Thor is borderline and fails with clouds. Hot Bird carries even less margin, by about 8 dB. Many users step up to larger dishes for stable 13E. [Elektroda, irekr, post #17395382]
Will a meter that shows the satellite name help avoid mistakes?
Yes. A finder that identifies the satellite removes ambiguity while sweeping. The OP’s Schweiger meter confirmed Astra 5E and 19.2E, and showed no lock at 13E. It cannot fix path blockages or an undersized dish, but it avoids aiming at the wrong bird. [Elektroda, 83pawel, post #17391728]
