Multiroom Signal in Multimedia Poland: Coaxial Cable vs LAN, CAM Modules & UPC Takeover Possibility
7032 3
  • #1 17119101
  • #2 17119190
    mojepetro
    grzesiek811 wrote:
    And what about two TVs with CI cam modules?
    When ordering the Multiroom service for an additional 10PLN / month you get a second CAM module with a card decoding the same package.
    And here curiosity:
    For me in Gdańsk, Multimedia simultaneously with an encoded digital packet also provides an analog signal (33 channels) and all terrestrial digital television channels (28 free channels).
    The lists are attached.
    • Kanały MM.xls (17 KB) You must be logged in to download this attachment.
  • #3 17119243
    kierbedz4
    Level 36  
    The cable from the box located in the corridor is inserted into the apartment ended with a splitter and from the splitter it is led out to individual TVs in which the CI cam modules are mounted. You do not pull anything from this, there is a fitter who will put an additional cable in the room. The service fee is added to the first invoice in the amount of about PLN 50.
  • #4 17119694
    KOCUREK1970
    Each tv must have its own cable signal.
    grzesiek811 wrote:
    I don't know if I should branch the signal and pull the coaxial cable to the other room or just the LAN.
    And both - a cable with a signal to each tv and LAN if the tv has internet functions.
