Choosing Between Bosch VarioPerfect WLG2426KPL & Electrolux EWS1266CI: Depth, Noise, & Efficiency
fido 7134 10
  • #1 17066278
    fido
    I need to buy a washing machine and I'm thinking about it
    Bosch VarioPerfect WLG2426KPL or Electrolux EWS1266CI
    Which one to choose or maybe something else, it is important that the depth can not exceed 40cm, maybe max 42cm but I would prefer up to 40cm.
    It is good that it would be quiet, economical etc. and a turnover of 1200.
    Thanks in advance for your help in choosing.
  • #2 17066429
    airwolff
    I suggest Bosch provided that in Germany foldable.
  • #3 17066447
    arekb81
    Level 30  
    Bosch: Noise level (washing / spinning) 58 dB / 85 dB - very loud.
    Electrolux: Noise level (washing / spinning) 54 dB / 77 dB - quite quiet
    I like silence and the choice is obvious to me. In addition, higher water consumption = better washed clothes.
  • #4 17066476
    airwolff
    Not necessarily higher water consumption = better washed laundry. Good water hardness + good detergent = better washed laundry.
  • #5 17066491
    fido
    This Bosch model seems to me to be assembled in Russia.
    As for the noise, will there be a difference for a normal bread eater?
    How is Electrolux and Bosch failing? To date, I use Indesita WISE 107 after replacing the bearings but it works for about 11 years but it may fall any day.
  • #6 17066502
    anet870
    Bosch is already padaka. Maybe it is worth looking at Amica?
  • #7 17066912
    airwolff
    Now almost all household appliances break down a few months after the warranty. That's such technology. :lol:
  • #8 17067947
    fido
    Or maybe some Samsung?
  • #9 17068781
    anet870
    Korean? .. Pyongchang has a lot to complain about :) Better Polish Amica because the service is closer :)
  • #10 17099727
    Damaran
    I have Samsung, for 6 years I only replaced bearings. How to distinguish models from Germany from other Bosch models? I am looking for a washer and dryer, because of the new apartment, we will buy new equipment because in samsung the drum shaft is already upholstered and even after replacing the bearings of the summer. I would rather buy a set but if it was possible to quickly and independently repair the washing machine, it would be nice.
  • #11 17099962
    80x86
    airwolff wrote:
    arekb81 wrote:
    ... the greater the water consumption = the better the clothes washed.
    Permission, but the water hardness at the installation site will be the same for each washing machine.
    And not with much wear. Just because one washing machine will use 40 liters of water per cycle, and the other 50, does not mean that they will wash in different amounts of water - one that can be rinsed in a larger amount or one rinse cycle more.
The discussion revolves around choosing between the Bosch VarioPerfect WLG2426KPL and the Electrolux EWS1266CI washing machines, focusing on depth, noise levels, and efficiency. Users highlight that the Bosch model has a higher noise level (58 dB washing / 85 dB spinning) compared to the quieter Electrolux (54 dB washing / 77 dB spinning), making the latter a preferable option for those prioritizing silence. There are also mentions of water consumption and its impact on washing efficiency, with some users debating the correlation between water usage and cleaning performance. Concerns about the reliability of both brands are raised, with suggestions to consider alternatives like Amica or Samsung, especially regarding service availability and repairability. The author emphasizes the need for a compact model with a maximum depth of 40cm and a spin speed of 1200 RPM.
Summary generated by the language model.
