Washing machine with the possibility of replacing bearings up to 1800 PLN.
zepter 7491 2
  • #1 16915248
    zepter
    Hello. The washing machine is supposed to be
    - loaded from the front
    - depth up to 55 cm
    - 7-9 kg of carrying capacity
    - min 1200 rot
    - price up to 1800 PLN
    I have read a few topics about washing machines with the possibility of replacing bearings and what you recommend are Bosch WAE washing machines currently almost not available unless replaced with a WAN series and Samsung, Amica and LG washing machines.
    Samsung is what to choose, for example
    https://www.oleole.pl/pralki/samsung-ww80j5346mw.bhtml
    but the whole eco bubble scares me away and the louder work from bosch by 6 db.
    I would choose Bosch from washing machines, e.g.
    https://www.oleole.pl/pralki/bosch-serie-4-maxx-wan2406epl.bhtml
    but you write that in the WAN series you can not replace only the entire washing group with bearings for over PLN 400.
    Some cross-bones crashed in LG.
    The more I read, I have a bigger problem with choice.
    I would like to ask you for a washing machine with the parameters given above.
  • #2 16915472
    petrol1
    Amica had folding drums - it was possible to replace the bearings, I do not know how it is now. Just tilt the washing machine and see from the bottom if the washing machine has a drum or a drum. If there is anything from the underside visible then the drum is glued.
  • #3 16915521
    zepter
    Theoretically you are right, but the Bosch WAN series has a supposedly unscrewed tank and the bearings can not be replaced. At least that's how someone in the 26th position wrote here
    https://www.elektroda.pl/rtvforum/topic3142343.html#15917302
    The consultant is right, the washing team - the tank is demountable, but as I wrote - the bearings are integrated into the back ladle. I do not know whether in all models of the WAN series or just parts - I talked to BSH about this topic half a year ago, maybe something has already changed here.
    The cost of the rear ladle is about 450 PLN on the factory service, and you will not buy it anyway.
    In the picture below you have an example price list of WAN series parts, please note that the bearing is not in the spare parts list.
    https://obrazki.elektroda.pl/1356837700_1473262949.png
