LG42LB670V TV Fails to Detect Terrestrial Channels: Antenna Power Supply & Troubleshooting
siara-siedlce 16935 6
  • #1 16791014
    siara-siedlce
    Hello, I have a problem tuning the LG TV, tv does not detect any channel from terrestrial TV, connect another receiver and everything works, so the cable with the power supply is working.
    The antenna is with a power supply.
    [Film: b59c28565d] https://filmy.elektroda.pl/7_1509439232.mp4 [/ film: b59c28565d]
  • #2 16791064
    electrotech
    It looks like a damaged TV head. Not only that, the TV can even properly receive an analog signal and the digital one is not also anymore, please do not suggest it either.
  • #3 16791114
    siara-siedlce
    and in no way does it go over this? that is, if I still have a warranty, it is worth reporting this fault, how can I be sure that the TV is actually a defect? so far I had a TV connected to the NC decoder + now I took it to work under the antenna with the amplifier.
  • #4 16791243
    _kli_
    In the settings option, you have probably selected a cable TV. Restore factory settings and reconfigure tv for reception by marking the source signal ANTENNA (terrestrial TV) and digital programs.
    http://www.lg.com/pl/wsparcie/poradniki-wideo/CT20198005-1439875159454-others
    If you know from which transmitter you receive terrestrial signal, it is better to program the receiver manually.
    In Siedlce, these should be 9,36,43,52 channels.
  • #5 16791310
    siara-siedlce
    I have already restored the system to factory settings. next the same "found 0 channels" I combined as much as possible in addition to manual programming.
    I go in manual tuning,
    options:
    Memory> System> Bandwidth> Program> Name
    I am looking in the "V / UHF AND CABLE" band and also does not detect any channel.
    I am looking for the System in every option and also does not detect it
    How to program differently manually with these channels what you wrote 9,36,43 ....
    _kli_
    The condition is to mark terrestrial TV as the source of the signal. When a cable or satellite is selected you will not find anything.
    LG wrote:
    Home -> Settings -> Quick settings -> Channels -> Channel tuning -> Manual tuning
    Allows you to manually adjust programs and save results.
    In the case of a digital signal, you can check the strength and quality of the signal.
    If another receiver works without any problems on this installation, you have a bad configuration or a damaged TV.
  • #7 16791383
    siara-siedlce
    Okay, after talking to the consultant and the various combinations and shadowing, I have to connect the TV to the Other Antenna, if the TV does not detect also on that channel, I have a damaged tuner. so we see each other in the evening with the answer to my query, thank you all for the hints. Greetings.
✨ The discussion revolves around an LG42LB670V TV that fails to detect terrestrial channels despite a functioning antenna and receiver. Users suggest potential issues, including a damaged TV tuner or incorrect settings. Recommendations include restoring factory settings, ensuring the TV is set to receive signals from the antenna, and manually tuning to specific channels. The author plans to test the TV with a different antenna to confirm if the tuner is defective.
