Samsung Galaxy S7 Range Issues: Signal Strength, AliExpress Imported Model, BTS Relay Proximity
131XIII 7908 4
  • #1 16756662
    131XIII
    A friend has a range problem, namely has a card from the play, has several other phones at home and lives very close to the BTS relay, and always has 5 strokes
    But his S7 barely has 2 lines, and sometimes he totally loses range, even though he is standing in the same place
    The phone was imported from China, but is intended for the European market (bought in aliexpress, from what he says)
    The attempt to change the software did not help
    Does anyone have any idea ??
    Thank you in advance for your answers ;)
  • #2 16756883
    alankulak1901
    131XIII wrote:
    The phone was brought from China
    Well, I'm not surprised.
    131XIII wrote:
    but it is intended for the European market
    So what? There are many fakes in Europe. First, check if it's the original. Egg yolks are getting better in counterfeit phones.
    As it will be the original, it's an antenna for exchange. The original will be checked after the IMEI number, enter * # 06 # and enter at https://imei24.com/en/imei_check/Samsung/
    if there are no errors, then you have the original.
  • #3 16756885
    sosarek
    131XIII wrote:
    he has a card from play
    Check it on another card.
    I understand that it does not even reach the keyboard to create a topic yourself?
    As on a different card it will be the same - to advertise.
  • #4 16757016
    E8600
    Perhaps the card is the culprit. I mentioned recently because I had similar anomalies with the network and I'm testing for now. Although the sim replacement in my case coincided with the update of the phone software, so it will be difficult for me to determine what really helped. link
    Are such circuses in the phone from the beginning? Perhaps the Chinese did something wrong, because the phone probably after rebuilding if it is original.
  • #5 16757797
    mobista
    Sometimes I wonder if posts on the elce do not write a bot ...
    To the author: where did the idea that writing a question in the forums give you a solution? Phone from cloneolandia, which theoretically has less than 24 months from the date of production and the question is he operational? The buyer saved PLN 142 for the purchase of chinola? Send a friend to a Samsung authorized service center, where they will check if the phone correctly transmits and receives the signal in the GSM network and after the case. On my eye, the disc has a defect or, as the predecessors have noted, it is poorly folded.
