Connecting A2212 / 5T 2450KV Brushless Motor to 30A Speed Controller & Using NE555 Servo Tester
xvip61 8811 3
  • #1 16743074
    xvip61
    I have a brushless motor for RC models and a speed controller for it.
    Regulator parameters provided by the manufacturer:
    Sustaining Input Voltage: 6-12V
    BEC Output Current: 5V / 3A
    Continuous Output Current: 30A
    Max current: 35A / 12s
    Engine:
    A2212 / 5T
    2450KV
    The question is:
    How to connect the regulator to the motor and is the NE555 servo tester suitable for control as described in the following post?
    https://www.elektroda.pl/rtvforum/topic871257.html
  • #2 16743127
    1 PAWEL
    I do not know if the NE555 servo tester will be suitable for control.
    Connection system motor / brushless controller -
    But the direction of rotation of the motor should be respected due to the direction of the L / R threads.
    CW - clockwise
    CCW - counterclockwise.
  • #3 16743165
    xvip61
    Well, I want to connect it, replacing the receiver with something else. That's why I was thinking about a server tester
  • #4 20062713
    DawiDD
    I know the topic is old, but xvip61 - have you checked if the serv tester is suitable for this purpose? Will the engine start?
