Adjusting Water Ejection Force in Geberit Concealed Frame (111.320.00.1) for Circle Ego Bowl
miszelos 91434 9
  • #1 16650021
    miszelos
    I have a Geberit concealed frame and the problem is that when flushing the water does not wash the front part
    bowl. Just like the strength of the water outlet was too small. Is it possible to increase the ejection force from the cistern?
    On the reservoir I have the designation: 111.320.00.1 and further: 01.14.01.04-2.3-KIWA
    Bowl Circle series Ego without collar.
  • #2 16650076
  • #3 16650141
    miszelos
    It seems to me from the beginning. We bought the apartment from previous owners. I did not pay much attention to it because earlier we had a bowl with a collar, also the Ego Series. now, after the exchange without a collar, such a malady appeared.
    Maybe the drain valve itself does not open completely and hence too little burst?
    I have no idea what to walk.
    I probably will not be able to return the bowls. I do not assume it is badly contoured ...
  • #4 16650204
  • #5 16650305
    miszelos
    I just do not know how to fool it all. I am afraid to move something not to damage or to put it back together.
    In general, the cistern has been in operation since 2004. There is some shit on the components.
    I thought to change the whole for new ones but I do not know how to do it ...
  • #6 16650363
  • #7 16650373
    miszelos
    Everything ok, I'm not sure if it will help me. Maybe just from those cisterns
    water flies so badly because I do not think that the valve would be able to regulate the release pressure. Works on an open - closed basis. Unless I'm wrong.
  • #8 17914613
    Jaapko
    I will dig out the topic, because it may be useful to someone. I have a new geberit concealed kit and a toilet bowl without a flange circle. The water also did not reach the front of the shells. It turned out that in the bowl, in the place where the water flows in there is a plastic cartridge that helps to spread the water inside the bowl to the right and left. The inside of the bowl was badly cast, so the cartridge could not fit into its place and block the flow of water. I pulled it out completely and the water beautifully flows around the whole shell with great strength. If someone was flying too hard and the water was splashing, then you have to combine with the plastic that was removed.
  • #9 19024412
    tatanka1972
    I have a similar problem with the wheel bowl. Unfortunately, it has already been mounted. How to take that hapless plastic out without ruining your bathroom. Please help . Andrew
  • #10 21038190
    damiancomperlik
    How to replace this plastic
The discussion revolves around the issue of insufficient water ejection force in a Geberit concealed frame (model 111.320.00.1) when flushing a Circle Ego toilet bowl. Users suggest that the problem may stem from the drain valve not opening fully or from the design of the bowl itself. One user mentions that a plastic cartridge inside the bowl, which is meant to distribute water, was improperly fitted, leading to inadequate flushing. Removing this cartridge improved water flow significantly. Others express concerns about disassembling the cistern and the potential for damaging components during the process. Overall, the conversation highlights troubleshooting steps and potential solutions for enhancing flushing performance.
Summary generated by the language model.
