Nexus 7 2012 WIFI - Eastern Kernel for Car Audio: Timur's Kernel, Features & Hosting Tips
malaoko 8061 8
  • #1 16627225
    malaoko
    Hello, I was looking for Nexus 7 2012 software that is needed for car audio, Timur's Kernel.
    I would like to share it with users because it is hard to find on the internet.
    Here is a description of the features of this rom:
    https://mehrvarz.github.io/usb-host-mode-power-management-nexus7/
    I don't know what hosting to upload I found first. If moderators have a problem I will change hosting.
    Moderated By nutergsm:
    Files should be added directly to the forum in the form of attachments.
    I added files.
    To unpack the archive use the 7z program.
    • Timurs Kernel 2012 Nexus 7 WIFI Grouper.7z.003 (40.74 MB) You must be logged in to download this attachment.
    • Timurs Kernel 2012 Nexus 7 WIFI Grouper.7z.002 (50 MB) You must be logged in to download this attachment.
    • Timurs Kernel 2012 Nexus 7 WIFI Grouper.7z.001 (50 MB) You must be logged in to download this attachment.
  • #3 17154201
    wojtek.szcz
    Can you please send it again? There is a problem with the files because there are errors when unpacking by 7z
  • #4 17154472
    nutergsm
    What exactly is your mistake? Unpacking must begin with the Timurs Kernel 2012 Nexus 7 WIFI Grouper.7z.001 file
    I downloaded all files and unpacked without problems.
  • #5 17156497
    wojtek.szcz
    Such a mistake here.
    I downloaded all three files. I use 7z
  • #6 17156538
    nutergsm
    I'm sending it again.
    • Timurs Kernel 2012 Nexus 7 WIFI Grouper.7z.003 (40.77 MB) You must be logged in to download this attachment.
  • #7 17156558
    wojtek.szcz
    There is also a question about what version of android is it? Can you install it on 5.1.1?
    Added after 8 [minutes]:
    Thanks :) now everything is elegantly unpacked. Can you please tell me if it will work with Android 5.1.1? I have a Nexus version without wifi. I do not want to bruise him so I prefer to ask for details.
  • #8 17169076
    dionizos
    Is there a chance that these packages were in .zip? Or what program to install rom in .7z format? How do I change this 7z with 7z File Converter - Bitser to zip and put on the device (Nexus 7 2012) reporting a file error.
✨ The discussion revolves around Timur's Kernel for the Nexus 7 2012 WiFi model, specifically its application in car audio systems. Users are sharing links to download the kernel and discussing issues related to unpacking the files using the 7z program. Some users encountered errors while unpacking, while others successfully managed to extract the files. There are inquiries about compatibility with Android version 5.1.1 and the possibility of converting the .7z files to .zip format for easier installation. Users are encouraged to share additional resources and solutions to assist others in accessing the kernel.
