Flush-Mounted Multimedia Box: Housing Router, TV Multiswitch, HDD Recorder & Patch Panel
marcinx00 10764 19
  • #1 16605997
    marcinx00
    Hello, I have a question for experts on the topic of multimedia switchboards, if the topic should be placed elsewhere, please move it.
    I want to install a multimedia box in a single-family house, in which I can put all the accessories I need.
    The box must be flush-sized, which will fit: router, multiswitch TV, recorder for recording with HDD from what colleagues in the previous topic wrote is also some patch panel and other necessary things like power sockets, maybe some ups.
    The following cables will enter and exit the switchboard:
    1) 9 antenna cables, it will be divided into 6 rooms where TV sets will be used (which multiswitch should be used so that it can also record another channel while watching)
    2) there will be 6 external IP cameras via twisted pair (including one from the IP video intercom)
    3) 15 points (sockets) in rooms and rooms to connect to the network (router).
    I would like to get a hint from you in which box I could fit it all I was thinking about the multimedia switchboard but they are usually 10 cm deep, the rack boxes too deep again because the wall is about 25 cm.
    Would it be possible to mount such equipment sideways in a switchboard with a 10 cm plate ???
    Is it better to take a deeper box? I found one 20 cm deep
    How about ventilation of such a concealed box? if it has holes in the door, is it enough to give some fan extracting heat accumulated there.
    This will be my first multimedia switchboard so I am asking for all tips on how I should do it (combine it) so that everything is fine.
  • #2 16606741
    Cr4sheR
    If you have so little space and there is no possibility of installation elsewhere, then buy a maximum deep box that you can mount, here you have several sample installations:
    Now there will be a problem of air recirculation, because each device will blow in a different direction, here it may not be too interesting and the devices from below will heat those at the top.
    I will also add that the recorder probably has a hard / hard disk (almost all), which when working in a standing position can shorten its life. + cameras will be powered from PoE Switch ???, which heat quite well, 6 cameras, so the switch can have even over 300W + 5-10W router + recorder? W and others = you can reach up to several hundred W = hot.
    According to me, this is bad practice, but if there is no other solution, you have to combine.
  • #3 16607567
    marcinx00
    Bad practice in terms of putting everything in one box?
    If so, I could divide it into two smaller only what dimensions should they be so that it does not turn out to be too small.
    I also thought about fans extracting warm air, possibly supply and exhaust
  • #4 16607858
    Rafq25
    There will be a problem with it. Do you have a garage or a basement in a single-family home?
  • #5 16607889
    marcinx00
    I've already let the cable shears into the storage space under the stairs because it is practically the center of the house and it will be easy for me to divide it into rooms
  • #6 16607900
    Rafq25
    I would do anything in the basement or garage. If you have it under the stairs then you can mount a small rack cabinet. Send pics. where it's supposed to be easier to advise.
    Alternatively, as you mentioned, install fans or do not install the door.
  • #8 16607928
    Rafq25
    As for network devices, patch panels and multiswitch in this cabinet. But unfortunately the camera recorder should be mounted horizontally on a shelf
  • #9 16607976
    marcinx00
    And the standard depth of the recorder how much it has because I saw some in the mini version
  • #10 16607999
    Rafq25
    What company do you have or will these IP cameras be? 6 pieces is a recorder for 8 cameras. One of the cheaper Hikvision DS-7608NI-K2 has dimensions 385 × 315 × 52.
  • #11 16608058
    marcinx00
    I don't know yet, I'm being built
  • #12 16608068
    Rafq25
    But we know that you want IP cameras. And these are enough to connect best to Poe switch. You can use the recorder or record it e.g. to NAS.
    On the other hand, we have 21 cables, why as many as 15 will go to the rooms? This is probably a huge house? It is with such an area that I would do it in the garage and preferably the basement. If you are under construction it is worth changing it
  • #13 16609156
    marcinx00
    House 180 m around 15 cables for rooms because despite the wifi these days I also want to have a cable.
    E.g. to living room 3 (tv, receiver with internet radio, ps console)
    To the kitchen 1, to the alarm 1, garage 1, up to four tv or 4 + still some sockets free is something about these 15 will come out.
    I want to do it under the stairs because it is the middle of the house and sections of antenna cables to the switchboard from the antenna and the rooms will not have to be colossal in length and it will be hardly visible behind closed doors.
    In addition, I have already carved a furrow in the wall where I released two 47 mm pipes to let the cables from the attic into this box, then with cables I will go to the attic again and spread it over the attic floor to the rooms
  • #14 16611673
    marcinx00
    I have already bought the box to which I gave links earlier, as it turns out too small I will add something next to it.
    I looked at the recorders and they are large because of the space for HDD.
    Some people do not recommend giving the recorder sideways but there are also opinions that it does not affect the life of the HDD.
    Something I can do maybe put everything in this box with time it turns out
  • #15 16612487
    Rafq25
    Upload photos after installation:)
  • #16 16612789
    marcinx00
    Ooooo, it won't be that fast unless everyone in the forum takes a screenshot of finishing the house :-)
  • #17 16613695
    KOCUREK1970
    @ marcinx00
    Of course, a colleague took (?) Into account the issue of cooling and ventilation of this place?
  • #18 16613756
    marcinx00
    I will combine with fans
  • #19 16673830
    Rafq25
    What inbox did you purchase? I am currently looking for a flat to rent. Under 4tv and 4 lan the one from photo 2 is cool and the last one knows what dimensions?
  • #20 16676469
    marcinx00
    I bought the one 20 cm deep, I mentioned that I bought it.
    It remains to be seen whether it is enough but not so soon because the condition of the house is not yet suitable for living :-)
✨ A user seeks advice on installing a flush-mounted multimedia box in a single-family home to house a router, TV multiswitch, HDD recorder, patch panel, and power sockets. The setup requires accommodating 9 antenna cables for 6 rooms, 6 external IP cameras, and 15 network sockets. Suggestions include using a deep box for better space management and considering ventilation solutions like fans due to potential overheating from multiple devices. The user is also exploring the option of dividing the setup into two smaller boxes if necessary. Recommendations for specific equipment include a Hikvision DS-7608NI-K2 recorder for IP cameras and considerations for the dimensions of the devices involved.
