Auraton 2025 RTH: F2 Display, Non-Responsive Buttons, Reset Issues & Transmitting Symbol
piczy83 32223 6
  • #1 14352249
    piczy83
    Hello, I have a problem. I connected the auraton 2025 rth. for a while it functioned correctly, when trying to change it turned off for a while and now only F2 and a small 5 are displayed at the number two. and the transmitting symbol lights up. Buttons don't work, reset doesn't help :?: Maybe someone can help :D
  • #2 14352280
    -west
    Heating systems specialist
    Are you under warranty yet?
  • #3 14352296
    piczy83
    rather not anymore, it was new for 2 years and only now I installed it :( I feel something has gone inside
  • #4 14355118
    piczy83
    for others with this problem, I called the service and they must be really good batteries!!! Regards
  • #5 15374825
    markam7
    i have the same problem, after a year of trouble free use of this device.
    If anyone has had this problem and knows a solution, please advise
  • #6 15544209
    gregoire_z
    I had the same problem - I replaced the batteries, everything and the hinge lit up permanently, removed and reinserted the battery and so far it's OK.
  • #7 15984947
    piczy83
    Replacing the batteries with new ones solved the problem.
The discussion revolves around issues with the Auraton 2025 RTH device, specifically displaying an F2 error and a non-responsive interface after initial functionality. Users report that the device stopped working after a period of use, with symptoms including a lit transmitting symbol and unresponsive buttons. Suggestions for resolution include checking warranty status, replacing batteries, and contacting service support. Several users confirmed that replacing the batteries resolved their issues, indicating that battery quality may be a significant factor in the device's performance.
Summary generated by the language model.
