Lamp Connection: Guide for 4 Ceiling Cables - Electrical Wiring, Gdansk Local Assistance
malejr3 38352 4
  • #1 13517171
    malejr3
    I'm here because I'm green when it comes to electrics, I did a search on the internet but didn't find the answer specifically. I need to connect my ceiling lamp. I haven't disconnected the old one yet. I love life and I need your help ... ;) Help where which cable.
    Thanks in advance and I buy beer in Gdańsk :)
    Lamp Connection: Guide for 4 Ceiling Cables - Electrical Wiring, Gdansk Local Assistance Lamp Connection: Guide for 4 Ceiling Cables - Electrical Wiring, Gdansk Local Assistance
  • #2 13517186
    Grubskee
    If everything is correct, it should be in accordance with the colors of the cables. Blue-Phase, Black-Earth, Brown-Neutral
    First of all, disconnect the power when connecting cables.
    Moderated By kkas12:
    3.1.11. It is forbidden to publish entries that do not contain substantive content, contain harmful advice, advice that is not an attempt to solve the problem, and the publication of identical entries consecutive or repeating information from the discussion.
    Everything should have its limits. Stupidity too.
    So Warning # 4 for using the error limit in the "guesswork" above.
  • #3 13517201
    witold04
    Hello, it shouldn't be like this
    Blue - Zero.
    Brown and Black - Phase, for double lamp.
    White - grounding, although it should be green and yellow.
    Please correct me if I am wrong.
  • #4 13517215
    wiki_25
    The correct system is given by a colleague witold, to be sure, check with the indicator where the phase is, but the photos show that the new lamp is only turned on at once, i.e. we connect it in place of the old one and after pain.
  • #5 13517261
    kkas12
    I am surprised by the confidence of my colleagues in their beliefs.
    The author of the thread should grab any gauge or at least a neon lamp and everything will be known.
    If it is so green that it cannot cope with it, the only thing left is contact with a competent person.
    And I am closing the parade of fairies (maybe a witches' coven?).
