Please help.
Please help.
Nie, dziękuję Przekieruj mnie tamstaszekel wrote:13 pin socket connection:
pin. no. - description
1. 44L - left direction indicator,
2. 52 - rear fog lights,
3. 31 - common ground for terminals (1-8),
4. 44R - right direction indicator,
5. 58R - right position light,
6. 54 - brake light,
7. 58L - left position light,
8. 62 - reversing light,
9. (+) -plus from the battery terminal,
10. (+) -plus after switching the ignition switch,
11. free - reserve,
12. free - reserve,
13. 31 - common ground for terminals (9-12).
This is how the 13-pin socket with tin-plated wire ends should be connected.
Wire colors vary from country to country.
With us, I suggest black or brown for a mass with a larger cross-section than the others, because the mass is common and a greater current flows through this wire than in the others.
I suggest (0.75mm^2) and for mass 1mm^2. With smaller cross-sections, there will be greater voltage drops and the cable will work as a resistance, which can be seen in the form of oxidized wires. I think it's all about the socket.
It is good to protect them from getting water.
Kind regards.
viper555 wrote:Of course they can be connected together, the only question is whether you will be driving with a caravan because pins 9-13 are intended for this, therefore such a mass cross-section, if not, these pins are unnecessary. Secondly, if you have a socket without a detachable fog lamp, the return will be unnecessary on the trailer and the car.P
viper555 wrote:If you want the original, then 13-4mm², while 3-2.5mm² is the maximum and it's best to connect each separately to ground.P
viper555 wrote:
TL;DR: 20 A is the stated fuse ceiling for a constant-plus feed, and “connect each ground separately” for reliability [Elektroda, Zico63, #9316229; viper555, #6790733]. Follow the pin map below to avoid lamp errors. Why it matters: Correct 13-pin wiring keeps lights legal, prevents CAN faults, and protects up to 3.5 A per lamp circuit.
• Pin 3 & 13 are both grounds; pin 3 serves lights, pin 13 powers caravan feeds [Elektroda, staszekel, post #6348607] • Wire sizes: 0.75 mm² for lights, 1–4 mm² for grounds, 4 mm² if caravan fridge is used [Elektroda, staszekel, #6348607; viper555, #6790733]. • Fuse ratings: ≤20 A on constant +30, ≤15 A on ignition +15 [Elektroda, Zico63, post #9316229] • Load limit: one 42 W stop circuit draws 3.5 A [Elektroda, Zico63, post #8520872] • 13→7-pin adapters cost approx. €10–15 online (eBay listing).
