Installing Windows 7 and Windows XP on One Computer: Dual Boot Guide for Separate Partitions
Sspam43 53340 25
  • #1 11896202
    Sspam43
    Hi !
    Now I have Windows 7, but I want to install Windows XP on one computer.
    I already have a separate "X" partition on Win XP 30 GB.
    But I do not know how to install I want to install Win XP from USB but I'm afraid that Windows XP will install where Windows 7 is, i.e. on Disk C.
    So what do you do to get it to Disk "X"?
  • #2 11896213
    goldi74
    During installation, you select a partition on which to install the system.
  • #3 11896215
    mickpr
    Windows 7 do you have x86 or x64?
    What is this Windows XP for? Maybe VirtualBox would be enough?
  • #4 11896223
    zolianek
    As @ goldi74 wrote. Additionally, you will need to set up bootMenu.
  • #5 11896228
    Sspam43
    I have Windows 7 x86.
    And Windows XP wants to install because 7 August is terribly muddy because of 256 mb ram. ._.
    The trick is that Windows 7 runs on 256MB of RAM.
  • #6 11896232
    zolianek
    The Seven runs on 256 mb of ram, but mussels. I don't know why you installed this Windows.
  • #7 11896236
    Sspam43
    I had VirtualBox but ...
    It feels strange to work with it.
  • #8 11896238
    zolianek
    You already know how to install. Now just a question. Will you still want to use the seven?
  • #9 11896247
    Sspam43
    I used to have 4352 GB of ram, but the bone of the 4 GB ram burned out.
    @zolianek
    Yes, I will want to use Windows 7.
  • #10 11896267
    mickpr
    With 256MB of RAM it doesn't even make sense to turn on the computer ... Seriously speaking.
  • #11 11896270
    zolianek
    mickpr makes sense, but to run 98 and not 7
  • #12 11896273
    Sspam43
    You can choose 100% on which partition has this WindowsXP installed?
  • #13 11896307
    zolianek
    Yeah
    Only then you need to set up BootMenu, and I don't know how to do it in the case of 7. In Vista, when you installed iX, you had to install VistaBOOTPro and choose to install BootMenu visty there
  • #14 11896342
    Sspam43
    Okay, I'm starting the installations.
    When I finish, I will write something; 3.
  • #15 11896428
    mickpr
    DOS too ... the question is, who uses such systems now?
  • #16 11896453
    zolianek
    Probably less than 1% of humanity :D . But XP with 256 MB can be launched and connected to the Internet, so it makes sense.
  • #17 11896569
    rafal131313
    First you need to install XP and then Win7 on another partition and then there will be 2 systems, if you do the opposite, there are problems and only 1 system works
  • #18 11896579
    zolianek
    @rafał on already has 7 and probably wants to install iX. And not. One system works, but at the beginning. This can be easily set up. I even remember how.
    Added after 8 [minutes]:
    It was like bootcfg / rebuild or something like that in cmd
    Even for sure. You type bootcfg / rebuid and you search for all elevator installations on the disks, then just name it, and you're done.
  • #19 11897029
    rafal131313
    When I install xp (on a different partition), xp will start after the installation, but not 7 - to start 7, you need to download the easy bcd program (requires net.framework2), and first in the manage bootloader tab select visty \ 7 bootloader, after restart 7 it will start, but there will be no choice - to select the systems you need to select the above mentioned 7 in the start menu - accessories right-click on the command prompt, run in administrator mode, and enter the commands
    bcdedit / create {ntldr} / d "Windows XP Professional"
    bcdedit / set {ntldr} device partition = C:
    bcdedit / set {ntldr} path \ ntldr
    bcdedit / displayorder {ntldr} / addlast
    after each enter command
    or install on 7 easy bcd, and in the add entries tab, select xp to add
  • #20 11897151
    bravo991
    Exactly, my colleague Rafał speaks well. If I install Xp without easy bcd, there will be a lot of errors and in total disks to the format.
    I know what it is like, I have two systems, xp and 7, but I gave 7 as the second system, because I had xp before. :P
  • #21 11897339
    blur
    I have not read any more stupid things here, firstly, you can install XP without problems after installing Win 7, secondly, who will forbid anyone, I have a few programs that do not work under 7 and it was also more convenient for me to install a second system next to it (hardware reasons). Thirdly, there is no difference whether 7 is 64bit or 32bit, where does this question come from? . Fourth, no additional software is required to add a second system of your choice to boot. Here is a description of http://szulcu.net/2011/06/instalacja-windows-xp-po-zainstalaniem-windows-vistawindows-7/ How to advise you, better go play in the sandbox, what do you think someone has RAM- u has as many as it has.
  • #22 11897656
    rafal131313
    It's much easier to use the easy bcd program (I also did this method when he said "blur" but something was wrong, but now I don't remember what but it ended up with formatting)
    and it's best to install it one after the other Win XP and WIN7 and then you don't need to do anything else.
  • #23 11898192
    blur
    It's probably easier to reinstall 2 systems and set everything up again than to tap in 4 lines of text, hands drop.
  • #24 11898736
    zolianek
    The easiest way to do this is to use xp's BootLoader and enter only one line.
  • #25 11899383
    rafal131313
    Count there are more than 4 lines of text
  • #26 11899473
    michalpurchala
    A colleague is right - why install the program? Ms has a program that asks us which system we want to turn on at startup. I installed and I know. Regarding that one question, XP is the most compatible with a variety of programs. For example, the microcontroller simulator "went" to me only on XP.
The discussion revolves around installing Windows XP alongside Windows 7 on a single computer, specifically on a separate partition. Users emphasize the importance of selecting the correct partition during installation to avoid overwriting Windows 7. It is suggested to use tools like EasyBCD to manage the bootloader, allowing users to choose between operating systems at startup. The conversation also touches on hardware limitations, particularly running Windows 7 on only 256 MB of RAM, and the compatibility of older software with Windows XP. Some users recommend installing Windows XP first, followed by Windows 7, to simplify the dual-boot setup.
Summary generated by the language model.
