Phase in Socket: Devices Not Working Despite Power Presence - Connecting Computer, Lamp & Printer
Rx_7 61966 24
  • #1 5895000
    Rx_7
    Hello, I have a strange problem that I have never encountered before, so there is a phase in the socket, but after connecting the device, nothing works ... although before the event everything worked in the same socket, the computer was always connected, a lamp, printer, monitor And now nothing works, even if it's a phase! Is anyone able to explain what is going on here or how to fix it? Nothing in the socket was changed or touched before incident. If I connect the lamp, it lights up by itself, but it literally only lasts for half a second every time! :?:
  • #2 5895024
    jurekN
    Somewhere on fire, zero check in the junction box socket or if the sockets are connected to the circuit of the previous socket.
  • #3 5895034
    krzysiek775
    In addition to the phase, there is also a neutral wire in the socket.
    Turn off the electricity, unscrew the socket and see if any of the wires have become loose.
  • #4 5895050
    Rx_7
    I just think I will have to check this junction box ... the socket itself has already checked all the cables are in place, but I'm not sure if the grounding is properly connected if it has something to do ... I will have to check again ...
  • #5 5895064
    diodi1
    Hello. When you ask such questions about grounding, I have only one advice, do nothing, just call an electrician who will fix it in a few minutes as it should be. greetings
  • #6 5895065
    Rx_7
    at first I thought that maybe the solstice was because there were too many connected devices, maybe, but everything worked unchanged, suddenly there is just a phase, but nothing I don't want to work individually, I would like to add that the washing machine in the bathroom also crashes plugs ??? but it's been a long time so electricity is pulled up from another room :) where is the turning point?
  • #7 5895090
    andziul
    Rather think of a new installation !!! You probably have aluminum conductors that are burnt in cans, have poor contact and cause short circuits. The current installation is dangerous for people - it won't be better !!!
  • #8 5895123
    jurekN
    Andziul, what do you have a glass ball that you know what the installation is there, let it change the apartment in your opinion.
  • #9 5895471
    andziul
    I did not mean to change the apartment, but to reflect on the condition of the current installation, which, from what my colleague Rx_7 wrote, apparently needs to be modernized. Maybe it's a normal situation for you when someone powers the washing machine from another room. The number of receivers in the apartment does not decrease, only the installation may not be demanding. My colleague Rx_7 may not describe his installation in detail, but some conclusions can be drawn.
  • #10 5895540
    jurekN
    Sir, and on new installations, there are such situations when someone does not tighten the cable on the terminal because of sloppy or forgetfulness.
  • #11 5896117
    andziul
    I would ask my colleague Rx_7 to describe the installation he has. :) Presumed age, what cables, type of security, block or single-family house.
  • #12 5897974
    Rx_7
    When I get home, I will check everything and try to describe what it looks like, thank you very much for the advice and happy world !!!
  • #13 5913302
    Rx_7
    So the socket has only two cables, i.e. phase and zero, I connected the ground but still nothing works if I connect even a lamp, and the phase is still there! As I wrote earlier, everything worked and one day the equipment simply stopped working (the lamp has a bulb). There is a rosette in the hall, and when I touched it, some sparks appeared, although nobody ever touched anything there, or maybe this shortage causes a defect? Why did it work before then? :idea:
  • #14 5913355
    Moon voyager
    Is only this one "socket" not working? or all around the house? Check wire connections. You must have a circuit break somewhere.
  • #15 5913387
    Rx_7
    all the others work, I am really surprised that the phase is not working? maybe there was less current, but I think the bulb would have caught fire! :idea:
  • #16 5913482
    Romulus7874
    You are sure this phase is it PHASE?
    And the mass is MASS?
    Once a friend had such a party. It turned out that the baked mouse was lying behind the paneling .... There was a current, but it was not there.
    But if the only thing that is known about the current is that "something is sparking there", it is better to call someone who knows.
  • #17 5913660
    garfild1985
    probably the neutral wire has burned out, as is often the case with aluminum.
    For a good start, disconnect the power and open the can from which it sparkles and see if there is a wire break there.
  • #18 5913667
    Rx_7
    I do not have a meter to check what the phase really is there, but I have this PHASER 777 which says that the phase is, but how high the voltage is, I do not know, but I will have to check this rosette because there are too many cables there and how lightly I touched some sparks of shear, maybe some the cables touch there, and it's a bit high and dark to check it today
    :idea:
    Added after 16 [minutes]:
    in this rosette in the hall there are burned cables, meaning the melted insulation looks like you will have to disconnect the plugs and put the cable in order!
  • #19 5914275
    Akrzy74
    Rest in Peace
    Gentlemen "prompters" think deeply if you do not want to have on your conscience Col. Rx_7 or his whole family! The problem could be much more serious. To remove such a failure / it is not one box / you need at least elementary knowledge in the field of installation.
    Col. RX-7-with all due respect, but call someone who knows it- Electrician :!:
  • #20 5914567
    jurekN
    I completely agree with my colleague Akrzy 74, if someone has no clue, he should not repair the installation, especially how to disconnect the junction box after firing.
  • #21 5920245
    Rx_7
    you have friends, I can do a lot at home and I like to tinker, although my profession is related to medicine, but I do not think I will solve why the phase shows, but the devices do not work, thanks for the advice again and I will let you know how everything went, best regards
  • #22 5927616
    Rx_7
    Fixed!!!! However, the problem was in the rosette in the hall, simply because the old insulation of the cable had melted until the wire broke off (as if it had crumbled). It seems the phase was there, but there was no zero. What today's pharmacists can like me :)
    thanks to the advice of colleagues. :D
    ps Thanks jurekN, you were right from the beginning!
  • #23 5927929
    Romulus7874
    Rx_7 wrote:
    Fixed!!!! What today's pharmacists can like me.
    In the case of electricity, the art of giving advice depends, among other things, on extreme caution.
    It is not known what knowledge and skills the inquirer has, and whether all data appearing in the "fault" are included.
    In fact, you never know for sure what will happen or what a forum member will do after following the advice given by other forum members (possibly relevant and helpful).
    Therefore, in order not to bear someone's health, life or property on their conscience (and not to be held responsible for it), many people recommend going to an authorized person or in this area.
    Nobody here negates anyone's skills, but if something goes awry ... Who advised it?
  • #24 5928741
    Dexter861
    I will add that if a colleague has old fuses, never "waddle" them and put a piece of wire in the fuse, because in the event of a short circuit (e.g. connecting a faulty device), you can burn the zero wire (which will work as a fuse) in its weakest a place that can be somewhere under the plaster and then even more work (forging, pulling wires, plastering, etc.).
    And one more piece of advice, I would really consider the sensibility of leaving the washing machine power supply from the next room to myself "because the fuse blows from the bathroom".
  • #25 5991397
    azboxik
    I am just struggling with the same problem. Fellow builders laid suspended ceilings without replacing the lighting system. (they made the nests) Bad luck wanted that a month after the renovation, the building was struck by lightning and, oddly enough, it was zero.
    Now cry and wail because you have to make windows in the ceilings to check the cans. :D :D :D
    After about 8 hours, I found the cause, currently replacing the entire lighting installation, and I have a question about it. What more or less can I impose the price for such an unusual service (replacement, plasterboard windows, additional "eSs", etc.). Will 50 PLN for each point be an exaggeration on my part?
The discussion revolves around a user experiencing issues with electrical devices not functioning despite the presence of power in the socket. The user reports that a computer, lamp, printer, and monitor, which previously worked, have stopped functioning. Responses suggest checking the junction box and ensuring that both the phase and neutral wires are properly connected. Several users recommend inspecting for loose connections, burnt wires, or faulty installations, particularly emphasizing the dangers of aluminum wiring. The user later discovers that the problem was due to melted insulation and a broken wire in a socket, leading to a lack of neutral connection. The importance of consulting a qualified electrician for electrical issues is highlighted throughout the discussion.
Summary generated by the language model.
